Page 1 of 2
Will a NC30 VFR400R speedo fit a NC35 RVF400 ?
Posted: Wed Dec 22, 2010 12:11 pm
by iSparkzz
As the topic says will it fit ?? and is it just a unbolt the old one and bolt in the new one?
Re: Will a NC30 VFR400R speedo fit a NC35 RVF400 ?
Posted: Wed Dec 22, 2010 1:58 pm
by Speedy
The internal parts are possibly interchangeable, but unlike the VFR, the speedo casing on the RVF is not detacheable from the tacho & temp guages. So it's not a unbolt/bolt job, but it's not too difficult either!
Q: Why do you need to change it?
Posted: Thu Dec 23, 2010 10:18 am
by iSparkzz
Speedy wrote:The internal parts are possibly interchangeable, but unlike the VFR, the speedo casing on the RVF is not detacheable from the tacho & temp guages. So it's not a unbolt/bolt job, but it's not too difficult either!
to be honest, i just want to do it because i like the look of the VFR speedo better
Posted: Tue Dec 28, 2010 10:45 am
by iSparkzz
Bump ?
Posted: Tue Dec 28, 2010 11:24 am
iSparkzz wrote:Bump ?
See the answer by Speedy - the speedo cannot be split on the RVF... :?
Posted: Tue Dec 28, 2010 12:55 pm
by iSparkzz
i still dont quite understand..
is he saying that i cannot unbolt and bolt in the vfr speedo to my rvf? if so why not. are the connections different? does it just not line up?
Posted: Tue Dec 28, 2010 1:00 pm
he is saying the RVF speedo is not a seperate unit..
Posted: Wed Dec 29, 2010 2:07 am
by iSparkzz
CMSMJ1 wrote:he is saying the RVF speedo is not a seperate unit..
ohh i see that make sense now. so how would i go about changing it thenn ?
Posted: Wed Dec 29, 2010 2:51 am
by Cammo
iSparkzz wrote:so how would i go about changing it thenn ?
What do you want to change?
Just the speedo? This can be done by swapping internals between the models.
The speedo housing? Can't be swapped, the rvf uses a single piece housing, the vfr is 2 piece.
The whole instrument cluster? Not a direct bolt on swap between the 2 models but could probably be dodged up by modifying mounts and swapping all the internals over. PITA job for no gain if you ask me, they look very similar....
The tacho? Not compatible between the 2 models at all.
Posted: Wed Dec 29, 2010 9:35 am
by iSparkzz
ahh i see.
well i like the look of the vfr speedo as a whole better, it looks more modern and updated and looks like they put some effort into it. but the rvf speedo to me is just dull plain and has nothing exciting on it which is why i wanted to do the swap.
i was just curious to see if it was just a simple job, but for all the effort i dont think is worth the gain, maybe one day..
one more question, does anyone know any speedos that bolt onto the rvf?
