Page 1 of 2
600rr panels?
Posted: Fri Dec 03, 2010 10:56 pm
by DK-Tandy
with my interesting of turning a CBR400RR NC23 into a 03/04 CBR600RR look a like.. do the fairing brakcets line up or are custom brackets needed?
Re: 600rr panels?
Posted: Sat Dec 04, 2010 11:37 am
by pugparcels
think you will find you will need to fabricate nearly all of the brackets to make the fairing fit. i have for my nc30 with 600rr panels, unless you are putting the panels onto the bike they were made for there will be some fabrication required*
*there will be some exceptions, 954 fireblade body fit directly onto a 929 blade - however the frame is the same, it is only the cc of the bike that really differs the majority is the same.
Re: 600rr panels?
Posted: Mon Dec 06, 2010 10:46 am
by DK-Tandy
ok thanks :)
what is best to use to make the brackets?
Re: 600rr panels?
Posted: Mon Dec 06, 2010 10:59 am
by pugparcels
depends on budget & the tools you have to fabricate them, i have managed to adapt most of the original nc30 brackets in my build and just used small pieces of stainless where requried.
Re: 600rr panels?
Posted: Mon Dec 06, 2010 11:10 am
by PARUS
I use aluminum to make brackets. You can find then in any building materials supermarket.
Re: 600rr panels?
Posted: Mon Dec 06, 2010 11:20 am
by DK-Tandy
thanks guys, i just hope when i buy the fairing, it all fits together!!
the farings i will be purchasing are:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
do you see anythng why they wouldnt fit?
or will i need the newer fairings on the bike??
P.S thanks for all the help guys, :), its much appreciated!
Re: 600rr panels?
Posted: Mon Dec 06, 2010 11:39 am
by pugparcels
i would guess it would fit, i made a 2004 body fit on my 1990 nc30. the only thing you made need, or maybe easier to buy than fabricate is the clock / top fairing bracket. i used the original nc30 one and then modified it for the 600rr fairing, but in using the original clocks as well i had to get a longer than standard speedo cable to reach the clocks as they are now further forward.
Re: 600rr panels?
Posted: Mon Dec 06, 2010 12:10 pm
by DK-Tandy
im going to use the 600rr front fairing bracket, and apparently the NC23 clocks dont fit, so i was going to purchase one of those aftermarket digital clocks that people put on offroad to road bikes to make them legall..
appartently theyre around £100 to £400 depending on style, brand name etc
Re: 600rr panels?
Posted: Mon Dec 06, 2010 12:17 pm
by pugparcels
some of the other regulars on here will know more about the digital dashes than i do. i used the original nc30 rev counter & temp gauge, replaced the speedo with a uk fireblade speedo. all i then had to do was find the longer speedo cable as mentioned.
i think digital clocks look far better, but i am working to a budget and this was a expense i did not really need.
do a search for digital speedos and im sure you will find plenty
Re: 600rr panels?
Posted: Mon Dec 06, 2010 12:29 pm
by DK-Tandy
yeah, i'm on a budget also, but as i also work, the budget gets bigger each week LOL
