Major Service Checklist.. Anything missing
Posted: Sun Nov 28, 2010 11:09 am
by iSparkzz
Well i decided it is time to get her serviced. As i have no idea on when it was service last or if there is something i should know about. I want it to feel like it should, cause right now it feels a bit dull and in need of a good service.
My list so far...
full check over of the bike making sure there is no cracks or anything damaged that i should know about.
new brake pads
new plugs
coolant flush and new coolant.
brake fluid flush
new leads (if they need to be done)
new oil filter
new oil
new air filter
new fork seals and oil
check the tuning and make sure carbys are balanced if not that done to.
money is no issue here as im selling another bike so i will have some to spend on her.
anything else i am missing?
basically i want anything and everything that can be done to it now so i know where its at and then i can start doing my normal service routine.
Re: Major Service Checklist.. Anything missing
Posted: Sun Nov 28, 2010 11:33 am
by hardnutdvd
you should probably include Valve clearances checked and adjusted if needed. there is a great guide on here how to do it.
Posted: Sun Nov 28, 2010 11:57 am
by Deadly_Viper
you could use and engine cleaner too, one that goes in the old oil before you change it.
Posted: Sun Nov 28, 2010 12:08 pm
by iSparkzz
good ideas... keep em coming pleasee
Posted: Sun Nov 28, 2010 2:48 pm
by hannakournikova
check head bearings,
wheel bearings,
chain and sprockets,
bulbs,
if you have a multi meter then check voltages across battery to see it reg rec ok,
fuel line and vacuum hose for splits
Posted: Sun Nov 28, 2010 6:11 pm
by samace
New sub air filter !!
:rocks:
Posted: Mon Nov 29, 2010 4:38 am
by karl BKK
Fuel hoses
Vacuum hose
check for any weak water hoses too, i had one burst open a while back, lucky i wasn't far from home and no damage occurred.
18 year old rubber is unacceptable, i wouldn't ride my bike with old hard perished tyres, sure as hell wouldn't trust 18 year old water hoses, so i'm changing them over as well as removing the thermostat (35+ degree Thailand) :)
I'm basically doing a major service like you this week (valve clearances, brakes, carbs, chain, sprockets, swingarm and wheel bearings previously done) so i'll be keeping an eye on this thread too.
Karl :)
Posted: Mon Nov 29, 2010 9:39 am
by iSparkzz
hannakournikova wrote:check head bearings,
wheel bearings,
bulbs,
All added to my list... thanks ;D
karl BKK wrote:Fuel hoses
Vacuum hose
Karl :)
will check both of those also :)
can anyone think of anything more ?
