nc30 with nc35 engine ?
myheroduane
Bike owned: nc30
Post by myheroduane »
ok so i know my engine is from a nc35 because its grey and i checked the numbers, anyways i was reading up on the differences between the bikes a came across some info regarding the frame. it said that the mounting points are different so how is it possibe my bike has a different engine?
Re: nc30 with nc35 engine ?
the mounting points on the engines are all the same.,..just some are used in some frames and not in others.. ;)
myheroduane
Bike owned: nc30
so will a nc35 fairing fit on it without modificaton?
abrmoto
Bike owned: RVFx5,SP1,MV F3,C90,Firestorm
Post by abrmoto »
You will need both fairing/clock and screen brackets, and rear sub frame if you want to fit full kit. Other than that will fit.
