Page 1 of 2
NC30 Spark Plugs - Removal.
Posted: Tue Oct 12, 2010 10:17 pm
by Phil_Norwich
Hey all, looking at checking the plugs on my NC30. From what I've heard, the front two are a bit of a bastard to do. Any hints, tips or tools needed to make it easier.
I've got to buy the plug spanner to get to the rears anyway as I haven't got anything long enough to get to them either.
Thanks in advance, Phil.
Re: NC30 Spark Plugs - Removal.
Posted: Tue Oct 12, 2010 10:28 pm
by porndoguk
get a universal joint, extension bar and socket, thats what i do for the fronts!
Posted: Tue Oct 12, 2010 11:36 pm
by Cammo
I usually take off the top radiator to to get the front plugs out but I think others say that you can just unloosen it and swing it out of the way.
A deep/long 13mm socket and a decent ratchet set are all that you need to remove the plugs.
Posted: Wed Oct 13, 2010 1:40 am
by phongus
I managed to get to the front plugs by removing the top radiator bolts and one of the lower ones and move it forward slightly. As Cammo said, just a 13mm long/deep socket and ratchet (maybe extension bar) is needed to get them out.
Posted: Wed Oct 13, 2010 3:50 pm
Cammo wrote:I usually take off the top radiator to to get the front plugs out but I think others say that you can just unloosen it and swing it out of the way.
I do this too... but I don't remove the radiator completely, just some of the bolts and swing the rad forward.
Genuine plug spanner
I use one of those too.. holds the plugs better :-)
Posted: Wed Oct 13, 2010 8:51 pm
by thunderace
The linky is a clutch spring
Posted: Thu Oct 14, 2010 11:39 am
wtf... it was a plug spanner y.day.. edited my origianl post but just incase
Try again...
Oh and that wont fit a 24.
Posted: Fri Oct 15, 2010 6:53 pm
by Malc
One of them "magnet on an telescopic pole" things or a "Japanese girlfriend with small hands" come in useful too for once you've unscrewed the plug.
Posted: Sat Oct 30, 2010 12:10 am
by spanky
+1 for magnet-on-a-stick (Maplins, £3 for a Rolson one) or if you're feeling tight then a lump of blu-tack up a long socket works as well....
Posted: Sat Oct 30, 2010 8:31 am
by thunderace
Neosophist wrote:wtf... it was a plug spanner y.day.. edited my origianl post but just incase
Try again...
Now it's a piston ring set
