Help/Advise needed.
Posted: Tue Sep 21, 2010 9:10 pm
Ok basically i have a nc30 which is currently running a ethos half system and a bluflame end can.
i followed the carb guide and jetted it 118 front 120 back, drilled slides raised needles and pilot screws set to 2 and 1/4 turns out and have tryed standard and dual density filters.
the problem being i still have a nasty flat spot between 4.5 and 7 thousand revs, im asking anyone if they have any recommendations or advise on curing this.
because if i cant get it fixed in the next month im going to revert back to a standard system and standard jetting etc.
my plan is to buy another set of carbs, ( im interested if anyone is selling). the plan being set up the carbs that are off the bike, then swap them over. see how it runs and adjust the other set thats off to try and cure it.
im also wondering if rvf carbs are going to have any advantages or not.
if anyone is running a similar set up, ie. half system standard engine & cdi, i would be grateful if you could share your settings so i could try them.
any help or advise will be mucho appreciated as i really want it running sweet.
im also interested in buying any sets of carbs , different jets etc.
cheers,
Ben
cheers,
Ben
