help!!!!
Posted: Sat Jul 12, 2008 7:41 pm
by Landy63
just a quick one, does anyone make a replacement rear hub/axel nut? and also how chuffin big is it? also where can i find a new chain adjuster wheel thingy because mine is chewed to pieces.
Damien
Re: help!!!!
Posted: Sat Jul 12, 2008 7:56 pm
by mick.mh2racing
Don't know where you'll get another nut from but you'll need a 36mm socket for it. If you take off the hub and file all the teeth back to sqaure, is as good as you're going to get or need. Most bikes will have some damage having butchered by screw drivers over the last 18 years. It's fairly soft aluminium so to file it square is fairly easy.
Re: help!!!!
Posted: Sat Jul 12, 2008 8:17 pm
by Landy63
ey up mick,
i tried a 36mm socket today and it was too small
? I recieved your parcel this morning, though thanks for sending it through mate. as soon as i get the axel nut off have ago at re-profiling the chain adjuster but untill then im not sure what to do lol
damien
Re: help!!!!
Posted: Sat Jul 12, 2008 8:35 pm
by wullvfr
the hub nut is 46mm........the wheel nut is 36mm... :D :D
Re: help!!!!
Posted: Sat Jul 12, 2008 8:39 pm
by Landy63
ha ha makes sense, but im having trouble finding somewhere that sells a socket above 38mm? even went to machine mart toady :) thanks for the info though mate
Damien
Re: help!!!!
Posted: Sat Jul 12, 2008 8:48 pm
by mick.mh2racing
Hi Damien, honestly to file the teeth square is easy. Sorry, yes to get the wheel off is 36mm and the nut on the opposite side is 46mm. Got both sizes if you need a borrow. Or drop your swing arm off here and we'll strip it down.
Re: help!!!!
Posted: Sat Jul 12, 2008 9:09 pm
by wullvfr
tool shop direct does 46mm sockets and for under a tenner...BARGAIN!!!!!
thats where i got mine :D :D
Re: help!!!!
Posted: Sat Jul 12, 2008 10:05 pm
by Landy63
your not wrong cheapest i could find was 14.99 off flea bay, thanks again mate
