Battery slowly loosing charge - HELP!
Posted: Wed Aug 11, 2010 1:14 pm
Hay all
Trying to find out why my VFR 400 NC30 is slowly draining the battery. So far I've taken it to battery centre who say the battery is fine and taken to a auto electrician who said the charging on the bike is fine!
So the only thing left is that there could possibly be a connection problem causing it to slowly drain the battery. I got a friend of mine to bring his multi meter and we tested a few of the connections
We measured the voltage across the battery and got a readying of +/- 12.75 volts. Then we tested for leakage which should not be more than 1mA our reading was 0mA
We then started the bike (bike was cold) and again measure the voltage across the battery and found that it was charging perfectly at about 14volts. The only weird thing was that when we revved the bike to about 3000 - 4000 rpm the voltage dropped to about 13.7 volts. I didn't want to rev the bike any higher as is was still cold.
Is this normal for the voltage to drop because the little that I understand is that it should increase the voltage not drop it. If this is not right what could be the problem?
