NC30 front disk bolt size?
Snap
Post by Snap »
I snapped one of the bolts that holds the disk in place. I drilled the bolt out but the thread needs tapping.
What size tap do i need?
Thanks.
superlite
Bike owned: TLS, LB80 x 2
Re: NC30 front disk bolt size?
Post by superlite »
M6 x 1 mm. You may need to helicoil it if you can't tap a decent thread though.
'Take it to the Back'
graham72
Bike owned: NC30,
Post by graham72 »
1mm???
Hissing sid
Bike owned: NC30+VFR750
Post by Hissing sid »
1mm is the standard pitch for a 6mm thread
BR
Neil B :rocks:
Snap
Post by Snap »
superlite wrote:M6 x 1 mm.
Thanks :mrgreen: 8-)
Snap
Post by Snap »
superlite wrote:M6 x 1 mm. You may need to helicoil it if you can't tap a decent thread though.
Worked a treat today. Thanks. :grin:
Didnt have to go down the helicoil route however ive snapped another bolt :o So i have to do it all over again.
