CBR400RR Specifications
tanuki
Post by tanuki » Mon May 31, 2010 10:43 am
Honda CBR400RR
History, Specifications And Technical Information
History
First manufactured in 1988 the Honda CBR400RR, or 'BabyBlade', is the smaller sibling of the Fireblade or CBR900RR series even though it preceded the 900cc Fireblade by several years. It was manufactured for the Japanese home market and from its release stormed straight to the top of the sales charts. The CBR400RR engine was a development from that of the CBR400 Aero, but had gear driven cams, an aluminium frame, a 17 inch front wheel and brand new styling complete with a twin headlamp fairing. It was referred to as either the ‘Tri-Arm’, a reference to its triangulated swingarm, or the NC23, its factory code. This domination of the Tri-Arm was continued in 1990 by the next generation of CBR400RR, the ‘L’ model, also known as the ‘Gull-arm’, or its factory designation the ‘NC29’. In spite of the superficial similarities between the Tri-Arm and the Gull-Arm, the Gull-Arm was in fact a completely new machine whose parts had much in common with the VFR400, including 17 inch wheels, front and rear. The name ‘Gull-Arm’ came from the bikes new swing arm design, derived from the, then, current race design a year after the swing arm was seen on the race track.
When the 900cc FireBlade hit the worlds markets and revolutionised the sports bike market in 1992 the Gull-Arm got the same paintwork and the FireBlade sticker on the fairing. Even though the 400 was the earlier design, it was christened the Baby Blade and went on to become probably the best selling ‘grey import’ in the UK.
Model Classifications, Dimensions And Weights
Model, Code and Production Year - CBR400RR-J (1988)
Frame Numbers - NC23-1020001 to 1036454
Engine Numbers - NC23E-1020001 to 1036510
Carburettor Number - VG04A
Wheelbase - 1370mm
Overall length - 2020mm
Overall width - 690mm
Overall height - 1110mm
Ground clearance - 120mm
Weight (dry) - 179kg
Model, Code and Production Year - CBR400RR-K (1989)
Frame Numbers - NC23-1090001 to 1098116
Engine Numbers - NC23E-1090001 to 1098123
Carburettor Number - VG04B
Wheelbase - 1380mm
Overall length - 2202mm
Overall width - 675mm
Weight (dry) - 182kg
Model, Code and Production Year - CBR400RR-L (1990 and 1991)
Frame Numbers - NC29-1000001 to 1010598
Engine Numbers - NC23E-1300001 to 1310636
Carburettor Number - VP01A
Wheelbase - 1365mm
Overall length - 1990mm
Overall width - 670mm
Overall height - 1080mm
Ground clearance - 125mm
Weight (dry) - 180kg
Model, Code and Production Year - CBR400RR-N (1992 and 1993)
Frame numbers - NC29-1050001 on
Engine Numbers - NC23E-1420001 on
Wheelbase - 1365mm
Model, Code and Production Year - CBR400RR-R (1994 - on)
Frame Numbers - NC29-1100001 on
Engine Numbers - NC23E-1500001 on
Carburettor Number - VP01B
Wheelbase - 1365mm
Ground clearance 125mm
Specifications CBR400RR-N
Type Four-stroke, dohc, in-line four cylinder
Capacity 399cc
Bore & Stroke 55.0mm x 42mm
Compression Ratio 11.3:1
Valve Train Gear Driven DOHC; 4 valves per cylinder
Cooling System - Liquid cooled, radiator with cooling fan
Clutch - Wet multi plate
Clutch operation - Cable operated
Transmission - 6-speed
Primary reduction - 2.117 : 1 (72/34)
Final reduction (sprockets) 2.600 : 1 (39/15)
Transmission - 6 speed constant mesh
Final drive chain - 102 links, split
Frame Twin spar, box-section aluminium
Front Suspension - Oil-damped telescopic forks
Rear Suspension - Single shock absorber with 3-way linkage
Front brakes - Double floating disc; 2-piston Nissin sliding callipers
Rear brake - Single solid disc; single-piston Nissin sliding calliper
Fuel tank capacity - 15.0 liters (4.0 U.S. gal., 3.5 Imp gal.)
Ignition system - Digitalized full transistor ignition
Starting system - Electric
Battery Type - YTX7L-BS
Charging system - Triple phase output alternator
Regulator/rectifier type - SCR Shorted/triple phase full wave rectification
Recommended engine oil -SAE 10W-40
Engine oil capacity at oil filter change - 3.4 litres
Idle speed - 1,300 +/- 100 rpm
Cold tire pressure (driver only, front) - 33 psi (2.25 bar)
Cold tire pressure (driver only, rear) - 33 psi (2.25 bar)
Cold tire pressure (driver & pass., front) - 33 psi (2.25 bar)
Cold tire pressure (driver & pass., rear) - 36 psi (2.50 bar)
Spark plug (standard) - NGK CR8EH-9 or equivalent
Spark plug (racing) - NGK CR9EH-9 or equivalent
Spark plug gap - 0.8-0.9mm
thanks to LoopyLee from Fireblades.org
Davez29
Bike owned: NC29 forever
Re: CBR400RR Specifications
Post by Davez29 » Sun Jun 13, 2010 2:50 pm
Some info on the various NC29 models.
Type 1 (Type 1 to 4 seem to be identical apart from colour).
Press release dated February 20, 1990. Type 1 (L). Release date March 19 1990. Price 699,000 yen. Expected sales 14,000 units per year
Frame from: NC29-1000001 to 101****, Engine from NC23E-1300001 .
Colour: Fighting Red/Pearl Crystal White (R-134/NH-193P)
Type 1 supplementary colours. The letter code matches the position printed in the fiche. A ? means unknown code or perhaps a decal.
A ?
B ?
C NH193P Pearl Crystal White
D ?
E NH193P Pearl Crystal White
F R134 Fighting Red
G ? (Rear Honda Decal)
Type 2
Colour: Granite Blue/Light Silver (PB-184M-U/NH-293M)
Type 2 supplementary colours. The letter code matches the position printed in the fiche. A ? means unknown code or perhaps a decal.
A ?
B PB184MU Granite Blue Metallic
D PB184MU Granite Blue Metallic
E NH293M Light Silver Metallic
F PB184MU Granite Blue Metallic
Type 3
Colour: Passion Red/Heavy Gray (R-109/NH-194M)
Type 3 supplementary colours. The letter code matches the position printed in the fiche. A ? means unknown code or perhaps a decal.
A NH1 Black
B NH193P Pearl Crystal White
C NH194MU Heavy Gray Metallic
D NH193P Pearl Crystal White
E NH194MU Heavy Gray Metallic
F R109 Passion Red
Type 4
Colour: Granite Blue/Heavy Gray (PB-184M-U/NH-194M)
Type 4 supplementary colours. The letter code matches the position printed in the fiche. A ? means unknown code or perhaps a decal.
A ?
B ?
D?
E PB184MU Granite Blue Metallic
Type 5 (Slight Model Change From Type 1)
Press release dated March 30, 1992. Type 5 (N). Release date April 7 1992. Price 710,000 yen. Expected sales 4,600 units per year
Frame from: NC29-1050001, Engine from NC23E-1420001
Colour: Pearl Crystal White/Dionysus Blue (NH-193P/PB-22B)
Type 5 supplementary colours. The letter code matches the position printed in the fiche.
A NH193P Pearl Crystal White
B R134 Fighting Red (Rear Honda Decal)
Type 6
Colour: Pearl Pure Black (NH-237P)
Type 6 supplementary colours. The letter code matches the position printed in the fiche. A ? means unknown code or perhaps a decal.
A ?
B NH237P
C ?
Type 7 (Slight Model Change From Type 5)
Press release dated Nov 19 1993. Type 7 (R). Release date December 15 1993. Price 739,000 yen. Expected sales 2,500 units per year.
Frame from: NC29-1100001, Engine from NC23E-1500001.
Colour: Ross White/Jockey Blue (purple) (NH-196/P-5M)
Type 7 supplementary colours. The letter code matches the position printed in the fiche. A ? means unknown code or perhaps a decal.
A NH196 Ross White
B P5M Jockey Blue Metallic (purple)
C ? Red Decal Colour (Atomic Red)
D NH193P Pearl Crystal White (Honda Wings Decal)
E P5M Jockey Blue Metallic (purple)
F NH196 Ross White
G NH196 Ross White
H P5M Jockey Blue Metallic (purple)
J ? Decal colour (Graduated E/C)
Type 8 (possibly R2?)
Colour: Sparkle Pearl Black/Procyon Red (NH-343P/R-203M)
Type 8 supplementary colours. The letter code matches the position printed in the fiche. A ? means unknown code or perhaps a decal.
A NH343P Pearl Sparkle Black
B R203M Procyon Red Metallic
C R203M Procyon Red Metallic
D NH343P Pearl Sparkle Black
E ? Decal
F NH1 Black
G R203M Procyon Red Metallic
H NH1 Black
The differences I can find between the earlier L and N models and the later R models apart from colour scheme are.
For the R model.. Cartridge forks with rebound damping also rear shock with rebound damping, different 4th gear, side lights in indicators (may be taken off uk bikes), no parking lights in headlamp, front discs pattern changed, exhaust headers thinner, different carbs with restrictors in inlets (marked 94) for 53bhp , various tolerances and fluid levels different, lights always on and different left switchgear, wiring harness different.
The only difference I can see is part number wise between the R & R2 is in the speedo, the only other evevidence is that in the R model owners handbook that it shows a drawing of a 85km/h speedlight fixed into the Speedo. I. have yet to see an actual Speedo with this item. here is a picture of the Speedo from the handbook.
All Known paint codes
The supplementary colour codes above are taken from the fiche and follow the same A,B,C guide as in the fiche. Things to bare in mind before you run off to RS Paints and make a big order is that the codes maybe for a rear number board, pinstripe, something like a gap in the decals or even a decal colour, such as in the rear Honda logo of a type 5. Check the fiche for more detail as the colour details are always marked on the bottom left of a page such as J14 with a Type/ABC format.Some codes and colours maybe repeated in the ABC column this is following the format of the fiche.
NH1 Black
NH105 Matt black (#15-#20)
NH109M Shot silver metallic special
NH196 Ross White
NH237P Pearl Pure Black
PB22B Dionysus Blue
R109 Passion Red
R134 Fighting Red
2TN110 Granite blue metallic-U/Heavy gray metallic-U
Thanks to vsource and any other party I have borrowed info or pictures from.
zul_cbr
Bike owned: 1990 CBR400RR-L NC29
Post by zul_cbr » Mon Sep 27, 2010 1:47 am
Anyone with NC23 brochures willing to share ? Mod, please delete my post if it is inappropriate.
Yakama
Post by Yakama » Mon Sep 27, 2010 9:10 am
Here you go:
zul_cbr
Post by zul_cbr » Mon Sep 27, 2010 9:59 am
Yakama wrote:Here you go:
Thanks so much Yakama for the 23 accesories flyer..! ;)
How about a sales brochure like this,
anyone ? Thanks again.
p/s - Mod, if u find this post is inappropriate, please delete. :peace:
Yakama
Post by Yakama » Mon Sep 27, 2010 12:05 pm
Sorry took a while as had to scan them all in, here you go:
I have also managed to find a copy of the 1992 HRC parts manual for the NC29, previously I had only seen the 1994 copy. If any one wants a copy I will scan it in.
zul_cbr
Post by zul_cbr » Wed Oct 20, 2010 12:20 pm
Thanks Dave for the 'NC29 Owners Handbook'... very rare..plus its translated too! ;)
Benneyboy@1984
Bike owned: cbr400 nc 23 aero Project
Post by Benneyboy@1984 » Thu Dec 16, 2010 1:41 pm
wicked post mate thanks lots of cool info there , im gonna risk my ass here but would anybody be able to put up some info on the 400 aero as this is what i ride but really is not a aero anymore its a impersonator of a later tri arm lol :grin:
thunderace
Bike owned: R6, YZF600R
Post by thunderace » Thu Dec 16, 2010 5:46 pm
Durka Durka wrote: Type 8 (possibly R2?)
That colour scheme is lush :drool:
Davez29
Post by Davez29 » Fri Dec 24, 2010 12:08 am
edited..
