NC30 Problem
lazyboydobby
NC30 Problem
Post by lazyboydobby »
I seem to be having a problem with my nc30 (VFR400). The main problem is that it seems to be starving itself of fuel. Underneeth the fuel tank that is what only can be discribled as a box with the fuel tap attached. Inside this "box" there is a few rubber diaphrams, at one side there is fuel out pipe and the other side of the diapram a small nipple. and above is the fuel inlet from the tank itself. I presume that the "nipple" is a vacuum pipe with moves the diaphram and stops fuel when the bike is not running.
I have checked the pipe and there are no leaks and have cleaned the "box".
It seemed to work fine for a day or so and has now stopped working again.
Will the bike run fine if i remove the diaphram or will i have problems with flooding??
ozracer
Bike owned: NC30 Race Bike
Re: NC30 Problem
Post by ozracer »
Do a search for HRC fuel tap mod and you will find all you need to know. First though you should find out why your standard tap isn't working. You may have a split in the vacuum hose that goes to the tap. You can check by taking the tank off the bike, turning the fuel tap on and suck on the vacuum hose. Fuel should flow, if it doesn't, there is a problem with the tap.
lazyboydobby
Re: NC30 Problem
thanks i had allready done that previously and checked the vac pipe.
The Mod has worked perfectly thanks :)
