Configuration voltage regulator of a R1
- Bike owned: 3xNc30,RSV Mille,Rs 125,Dnepr
Hello,
can somebody tell me who is the configuration at the voltage regulator of the R1 RN1?
I need the position of the red an the green.
The other three I have under controll....
Thank you
Thank you
Re: Configuration voltage regulator of a R1
Whats the R/R look like?
3 yellow stator wires go to gray plug. It doesn't matter which yellow wire goes to which prong. Then you have green wires and red wires. The red wires go to the black plug on the prong closest to the gray plug. The green wires go on the black plug on the prong furthest from the gray plug. The middle prong on the black plug is not used. Use a good quality electrical connector for each wire to it's prong.
