				600 hybrid jetting
				Posted: Thu Apr 22, 2010 9:11 pm
				by bendy3
				Hi, anyone know what jetting works on a 600 hybrid. Mines on open carbs at the moment with 145 mains std I think and wont pull through the rev range as it leans of when you crack the throttle. Anyone running individual filters and know what main jets they have in?
				Re: 600 hybrid jetting
				Posted: Thu Apr 22, 2010 11:25 pm
				by cagiva996
				is it for a race bike or for the road?if its for the road where youll need some midrange unless you ride flat out everwhere
  dont bother with  filters-they are an absolute BASTARD to get right,unless you have access to a dyno of course and are prepared to spend some cash.even the hybrid race bikes ive seen use some sort of airbox to get the fuelling right.the only one ive seen using filters was using 190 main jets and alot of time trying to get it right-it went like stink but had little midrange.hybrids using airboxes still kick out anywhere between 85-95bhp and the gains with the filters at the top are at the expense of driveability.but if you want some t/cat 4jh k&n filters ive got a brand new pair that i fitted while i sent myself crazy trying to jet my hybrid properly.the two filters  are as new(one filter goes over a pair of carb each) but you have to remove the intake trumpets on the carbs.for your sanitys sake look at fzr tims hybrid build and look at how he modded his airbox-it works.on the other hand if you manage to get it right-post it up here!
ps 4jh/t/cat standard jetsare 118-and 120 if i remember right- ill go and check
				Posted: Fri Apr 23, 2010 12:49 am
				by barryfzr
				mY thundercat engine one has got a 1wg airbox with a K+N filter...had to get it dyno'd in Bristol though at Tim Blakemore's...nice guy but £300
				Posted: Fri Apr 23, 2010 10:33 pm
				by plodder
				Mine has 3TJ airbox melted corners to fit, no snorkel and a 70mm hole below the filter removed to get air in through to the bottom of the filter.
#42 pilot jets
Dynojet mains & main air jet blanked (carbs were dynojettd when I got them).
It was the pilot jets that sorted my cracked throtte lean-ness.  There's a place in New Zealand I got 4 jets for about £12 delivered in a week.
I tried it without the airbox and it was horrible.
It's a bit peaky but between 6,000 and 13,000 it stays with the inters trackday group on the straights and it's a hooligan tool on the road.
				Posted: Sat Apr 24, 2010 9:35 am
				by bendy3
				Going to have to make some kind of airbox then. By the way its LOUD
				Posted: Sat Apr 24, 2010 11:49 am
				by cagiva996
				i hope your freindly with your local m.o.t tester or he is deaf as a post
				Posted: Sat Apr 24, 2010 5:37 pm
				by bendy3
				Modded a 3tj airbox to fit and got a big improvent on power. I can get it screaming it now.
