starting problems
starting problems
well where do i start ??
bike wouldnt start so ut new plugs in, fired up straight away
started it a few hours later on the choke and the nike just died, now it wont start again
any ideas ??
i dont want to damage the new set of plugs i have just purchased,
checked spark on all leads
can smell fuel
what else can it be ?
any ideas ??
can smell fuel
- richhemmings
- Bike owned: VFR400 NC30
Re: starting problems
obvious questions...
does the engine turn?
are the sparks STRONG?
fuel line isn't pinched, and tap is open?
didnt over-choke and flood? - was the first start on the choke?
i just noticed that there is a kink in the vacuum pipe,
im assuming that when it started it was using the fuel already in the carbs and now it can get anymore as the vacuum pipe is kinked ??
- richhemmings
that would be my first guess... it does try to start then??
well, after it stalled it tried to fire once more but i guess there snow no vacuum for the fuel to the carb so just turns over,
- richhemmings
That's what I meant mate... rules out electrical problems.
if you're getting a decent spark too, i'd reckon its fuel problem, or carb setup/configuration.
(anyone else... can't think what else it could be?)
what were you working on between the first and second runs? its likely you've just knocked something off...
sort out the hoses and let us know how you get on... I'm off to catch some Zzz's - long day!
just replaced the vacuum hose and still wont go,
its so close and now im out of ideas ??
i have replaced the plugs and checked them again, the bike is not flooded as the plugs are still clean
i have checked the spark and can see one visable
pls help
pls help
- richhemmings
only one is sparking?
there should be a strong blue spark between the central and side electrode.
if not, check your HT leads, packs and central distributor.
for HT leads...
you can bite ur tongue, and hold each one while you turn the bike over (you'll get a small shock) or .. :D
put them in turn against a ground point (frame) and turn the bike over... if the leads area degraded, you'll see a spark between the lead and the frame.. if this is the case, the leads have broken down and you'll need to replace them...
sometimes even new plugs fail...
for HT leads...
all plugs have a spark,
the bike does want to start, i have taken the tank off again and when i did this before there would always be a little bit of fuel in the fuel pipe, today its dry ??
- richhemmings
but you have fuel in the tank? check that there is suction on the end of the pipe - disconnect the hose from the tap to the inlet on the carbs at the carb end - turn the engine over and listen or feel for suction at the end of the pipe.
