bodywork,how do you fit yours ?
- royster81
maybe it's a simple straight forward anser but what do you guys use to hold your mid panels to your lowers ?
i had dzus clips ( the clip version not the rivet) that would have been ideal but when i went to fit them this afternoon i have only 2, i rang around a few laces and all they stock is rivet clips.
so what do you boys use, a nut and bolt, dzus clips, cable ties ?
- leopard_pagan
Re: bodywork,how do you fit yours ?
push on DZUS like the 2 you have. mind you, you'll be surprised how many bike shops have no idea what they are!
the rivet type, i dont think you need to rivet them. just pinch them tighter and they should be fine.
- Variablevalves suck
http://81.171.195.25/products/ProductDe ... P336400190" onclick="window.open(this.href);return false;
Clipon listed at demon tweeks.
- royster81
cheers V, what about the 1/4 turn screws, is it just 10mm depth required ?
Think they do different lenghts depending on the app. if you click on the fasteners heading in the link they got allsorts of stuff.
LUCAS
- Bike owned: NC29 and NC35
I bought some Dzus fasteners from eBay. They're the 1/4 turn ones and are great. Loads on eBay....
http://cgi.ebay.co.uk/Dzus-fasteners-Ho ... 500wt_1182" onclick="window.open(this.href);return false;
- royster81
i'm not sure you can use the D-ring type 1/4 screws as the bodywork has a recess for the normal screw type to fit in and the D part doesn't fit into it.
LUCAS
Oops sorry i copied the wrong linkroyster81 wrote:i'm not sure you can use the D-ring type 1/4 screws as the bodywork has a recess for the normal screw type to fit in and the D part doesn't fit into it.
I just checked my Dzus fasteners and they are 17mm in length like these (hopefully right link this time
http://cgi.ebay.co.uk/QUICK-RELEASE-DZU ... 2583wt_978" onclick="window.open(this.href);return false;
LUCAS
Ok all the talk about how i fit my bodywork together with Dzus fasteners and i have gone and lost one today
Going by eBay you would have thought they were made of gold!!! Approx £5 for one
- leopard_pagan
i took the D rings off mine...they all have a slot for a flat screwdriver
