TPS on NC29 racebike
Posted: Thu Jun 26, 2008 6:18 am
I was wondering, as I've heard different things from different people.
I run an HRC CDI on a modified standard loom, red/blue wire from the CDI runs direct to the +ve terminal of the battery (although I think this is redundant with the HRC CDI), and I have the TPS connected.
When trying to tune the bike at the beginning of the year we discovered that there was a difference between having the TPS connected or not connected. This is despite having been told that the TPS is redundant with the HRC CDI. I had one person swearing black and blue it's not on an HRC loom so makes no difference, and then the obvious evidence that it does make a difference. For the record the power curve was rough with more dips and peaks than a nudest beach when it was disconnected, and much smoother when connected.
Does anyone know what the story is here? Is there a common mod here that I may have missed? I.e. wiring the switch into the permanent 'open' position?
