Throttle sticking
Posted: Sun Feb 28, 2010 4:20 pm
So my throttle is sticking. Wind the power on, let go and it hangs and doesn't return
So far I have checked the return spring on the carb - nice and healthy and now regreased
Oiled the cables - one is very free moving, the other there is a little more resistance in it.
Checked the routing - seems ok. Not catching or rubbing or kinked.
Had the throttle grip apart. Greased it. Cut back the rubber grip. It still sticks.
Prob seems to be throttle end. If I take the bar end weight off and slide the twist grip off to the side keeping the cables in it then it will work fine and snap back but if I slide it into position on the bar it won't.
Not a major thing, just a bit annoying. Thinking of changing one of the cables. Unless any of you has any other ideas?
