exhaust gaskets
Posted: Fri Feb 19, 2010 6:51 pm
by Deviant400
are the exhaust gaskets at all points of connection , ie front down pipes to cyclinder head rear manifold to cylinder head and the connection to the rear manifold to downpipes all the same
Re: exhaust gaskets
Posted: Sat Feb 20, 2010 4:28 pm
No
Re: exhaust gaskets
Posted: Sat Feb 20, 2010 6:59 pm
by Deviant400
thanks neo , i thought as much , just needed those numbers cheers
Re: exhaust gaskets
Posted: Sat Feb 20, 2010 10:02 pm
Deviant400 wrote:thanks neo , i thought as much , just needed those numbers cheers
No problemo :)
Re: exhaust gaskets
Posted: Sat Feb 20, 2010 10:25 pm
by Polisher
Ive just replaced my downpipe to cylinder gaskets (not the 2 collector gaskets)and manifold gaskets and although the part numbers are different they are identical!
Same materials, internal and external diameter and thickness, no idea why Honda use differnt PN's!!
Re: exhaust gaskets
Posted: Sat Feb 20, 2010 11:13 pm
by Deviant400
hrmmm well i ordered a set of 4 from D/S but knew i needed 6, wernt to sure if they were the same or not , so ordered the 2 now, now ive got the bastard job if replacin the manafold as i snapped one of the bolts on it arrrgh
cant belive i have to destroy the entire back end for the sake of one poxy bolt and armed only with a single sided p/s and no axle stands this is gunna be fun
Re: exhaust gaskets
Posted: Sun Feb 21, 2010 2:41 am
There are a few ways you can get the bolt out.
- Soak it in lots of plus gas / blowlamp it and use some pliers if you can get a grip on it.
- Put a slightly bigger nut over the stub and weld it onto the bolt then you can undo it with a socket.
- If you can get a drill in there, i used this method when i snapped a front bolt. (much easier to get to tho) (taught by my very knowelegable uncle) tighten the chuck up on the stub and undo it slowly on the torque setting
Re: exhaust gaskets
Posted: Sun Feb 21, 2010 11:20 am
by Deviant400
yeah i got the pipes off the manafold ok , just the middle bolt that holds the rear down pipes to the manafold sheard right off when i was undoin it so now i have to replace the manafold to one that has 3 bolts(thanks geoff33 yet again for sendin me one) so i can put it all back together, but getting the old manafold off is summit of a mission or what!!
ive only a single sided paddock , on the hunt for some axle stands now so i can remove the shock to gain access arrrgh
all for the sake of a 20p bolt
Re: exhaust gaskets
Posted: Sun Feb 21, 2010 4:22 pm
by Deviant400
update yay!!! ive managed to cut the offending stub that remains of the bolt off and drill thru the hole, found a sutable bolt to go thru so jobs a goodun , quick fix but will change the manafold over in the near future when i do the swingarm bearings , next job on the list
the 2 gaskets i removed from the manafold are diffrent , much thinner and more like washers than the thicker gaskets for the front downpipes
Re: exhaust gaskets
Posted: Sun Feb 21, 2010 10:22 pm
Deviant400 wrote:update yay!!! ive managed to cut the offending stub that remains of the bolt off and drill thru the hole, found a sutable bolt to go thru so jobs a goodun , quick fix but will change the manafold over in the near future when i do the swingarm bearings , next job on the list
Yeah, I seem to remember that they are different. I ordered a full gasket set for my NC24 from Japan but when it came it was an NC30 set.
