Page 1 of 2
16T, 520 pitch front sprocket
Posted: Wed Feb 10, 2010 12:49 am
by greggo
Anyone know if there is one available for the NC29? Would prefer to source one local, is there another make model etc that uses the same?
Thanks.
Re: 16T, 520 pitch front sprocket
Posted: Wed Feb 10, 2010 1:08 am
by Cammo
Greg, if vfr ones can be used I have a spare used 16t 520 that I don't need (I'm too slow for it!).
Not sure of condition but will get back to you if you want it.
Posted: Wed Feb 10, 2010 4:04 am
by greggo
I know the splines fit, not sure about the offset but that can be bodged, I'm keen if it is useable!
Posted: Wed Feb 10, 2010 5:35 am
by Cammo
No worries mate will get a pic and some measurements to you tomorrow.
Posted: Wed Feb 10, 2010 7:07 am
by Cammo
I checked the RVF and the NC29 HRC manuals and they used the exact same part numbers for sprockets so it should fit no worries.
PM sent.
Posted: Fri Feb 12, 2010 9:03 pm
by mickj23
greggo
you can use a renthal gixer front sprocket on a nc29 16T
the sprocket is flat on two sides, it has no flanges,
just cut a couple of spacers.
came across it by accident looking for the same solution
have used this set up for the last couple of years.
will give you the number for the sprocket tomorrow
not near the bike tonight.
if thats any help
Posted: Fri Feb 12, 2010 11:37 pm
by greggo
Cheers mate, thats handy!!!
Posted: Sat Feb 13, 2010 12:46 am
by cappa
Greg, why are you gonna run a 16t front? what track? :?
Posted: Sat Feb 13, 2010 3:59 am
by greggo
Phillip Island. Last visit I was hitting redline just before the bridge in 6th and couldn't go any taller than 15/39.
A 16 tooth front gives me a bit more flexibility.
Posted: Wed Feb 17, 2010 12:10 pm
by grant98
i was having the same problem .check out the jt sprockets website it has all the dimensions for every sprocket the closest i could find is an r6 sprocket i think you need about a 1mm spacer
