Signs Of Failing Reg/Rec
				ChowderV4
i have a intermitent electrical problem with my bike where the battery isnt getting enough charge and sometimes it doesnt turn over and then others it does. whats the signs of a reg/rec going.
sometimes if the bike is run and stopped it will not turn over.
then sometimes if i leave it over night it starts first time in the morning.
hellllp
hellllp
				Lope
Re: Signs Of Failing Reg/Rec
how about searching the forum?
this question has only been asked 999999 times
Fully charge your motorcycle battery and follow this guide from start to finish, should help you find what parts of your charging system are playing up.
Sounds like your batterys either had it, or your charging system or both! This guide will test em all :)
http://www.electrexworld.co.uk/pdfs/Tro ... G-&-RR.pdf" onclick="window.open(this.href);return false;
