Fuel Tap - On or Off.
Phil_Norwich
I can't see my NC30 getting much use in the next month or so.
I was wondering when leaving it standing is it best to have the fuel tap switched to the off postition or doesn't it matter?
Thanks, Phil.
Thanks, Phil.
- banoffee
Re: Fuel Tap - On or Off.
would have thought it made no difference considering it's vaccum fed
I'd leave it off just in case. The taps are getting old and a leak into the cylinders, if your carbs also play up, is not a good thing.
avinitboys
- Bike owned: TRE NC24 NC30x2 GK76a KTM250
Yeah I'd go with off too. Better to be safe than sorry. Oil aint a cheap thing if petrol ends up in there with it! Unlikely, but it can happen.
hksooie1
- Bike owned: a few Nc30s and Ducati 748
I'd probably turn the tap off then run the engine to clear fuel out of line/carbs.
Phil_Norwich
I did think about switching it off then running it to dry but I don't think it'll be left that long to justify that. I'll just stick it to off for now.
Cheers.
Cheers.
Lope
Some people who have carb problems, turn their fuel tap off every time they turn the bike off.
One thing I've been wondering, how many times can you turn the fuel tap on/off before its knackered? Surely you incur wear on it from turning it on/off all the time.
I doubt its designed to be turned on/off every day?
Not just the risk of replacing the oil, can also damage the engine.
VfRTeddy
- Bike owned: Vfr400 nc24
yer i would know about that one lolavinitboys wrote:Yeah I'd go with off too. Better to be safe than sorry. Oil aint a cheap thing if petrol ends up in there with it! Unlikely, but it can happen.
an are the NC24 taps vaccume fed aswel?
Ben
Lope
In standard form yes.VfRTeddy wrote:are the NC24 taps vaccume fed aswel?
VfRTeddy
ahhh sweet cheers mate
Ben
Ben
