Fork Protrusion Through Top Yoke
Posted: Wed Jan 27, 2010 7:01 am
by DoktorMandrake
How much should the fork stick through the top of the top yoke? I assumed as it looks like it's set that there'd be a value in the Haynes. There isn't. Just says make sure they're even.
So how many mil do you lot normally have your forks sticking through the top yoke by?
Re: Fork Protrusion Through Top Yoke
Posted: Wed Jan 27, 2010 9:16 am
by abrmoto
Forks should be flush with top yoke, if you push them through you will smack your rad with front wheel on heavy breaking.
Posted: Thu Jan 28, 2010 7:36 am
by DoktorMandrake
Thanks Abr! Will set them flush then. Don't like the sound of anything twatting the rad.
Posted: Thu Jan 28, 2010 1:23 pm
by dr_46
i have them about 10 mm through the yoke and never had a problem i have a tiger kit on if that makes a diff...
Posted: Thu Jan 28, 2010 9:51 pm
by Cammo
I have them set about 5mm through to help turn in (as well as raised rear).
If you're using original bodywork then the front wheel will hit the fairing v-piece well before the radiator.
The proper sized front tyre (120/60) and firm fork springs will also help it not to hit.
