wanted fzr400rsp 2tk single seat unit & petrol tap
- Bike owned: 954 blade,
as above, I know theres little chance of getting either but its worth a shot. The petrol tap is probably used on lots of fzr,s, sure they often break with peeps heaving the tank off in a hurry.
I have a seat unit but some owner decided to cut the top of it away to make a space for a pillion seat doh!
- Bike owned: 2tk virago vx 750
Re: wanted fzr400rsp 2tk single seat unit & petrol tap
i also need one mine is snap lol
Get them new from Fowlers you'll need to quote the frame number (also on the V5)
Get the lever and the screw that holds it on as well.
are they same as 1wg or 3en can you get them in separate parts or a complete tap
It comes as an assembly. The lever and screw are separate it's about £30 all in.
This is based on my 3en2
Might be able to help .....gotta shoot so will pop back
Thanks barry.
yep I put fzr600 fuel taps on mine. I should also put a sticker on the tank near the fixing brackets saying "FUEL TAP!!" ;o)
If you post up pictures I can tell you what you might need.
was it a straight swap
yep .... fzr6003he 1989-1993 ;o)
