NC35 Wheel spacers
Posted: Fri Jan 08, 2010 4:50 pm
by Drunkn Munky
Anyone got a set of standard front wheel spacers to hand they can measure for me? The ally captive ones i have dont sit inside the bearing rubber on the new PVM wheels ive got like they do on the standard wheels, not really a problem but the wheel doesnt line up either!! the disc hits the left fork leg, swapping the spacers round allows the wheel to spin but still doesnt line up with the calipers. Turn the wheel round and put the spacers back where they should be and everything lines up perfect, except now the tyre is running the wrong way.
Now i know your all gunna say i got the tyre on the wrong way but i had it fitted the same way as michael (the previous owner) had his tyres fitted so i just wanted to check the ally spacers i have are not causing the problem before i go and get the tyre swapped round.
Re: NC35 Wheel spacers
Posted: Fri Jan 08, 2010 6:43 pm
by hunter
are there no directional arrows on the wheel.
Posted: Fri Jan 08, 2010 7:38 pm
by Drunkn Munky
No, michael did send me a pic with a tyre fitted to show direction but he must either be running the tyre backwards (unlikely), using different spacers or the ally spacers i have dont work with the wheels, again unlikely as there fine with the standard wheels.
Posted: Fri Jan 08, 2010 7:44 pm
by fastdruid
The search will find this for you :-)
NC35 spacers are 21mm and 28mm wide
Druid
Posted: Fri Jan 08, 2010 7:46 pm
by Drunkn Munky
:oops: cheers druid
New years resolution....stop being a lazy fecker :peace:
Posted: Fri Jan 08, 2010 8:00 pm
by fastdruid
Drunkn Munky wrote::oops: cheers druid
To be fair I knew they were there because I posted it :-)
Druid
