				5" rear wheel fitment
				Posted: Fri Jun 20, 2008 2:25 pm
				by Davoofteambogus
				Does anyone know what larger rear wheel goes into an NC29? I am looking for a wider rim ie 5" rather than the standard 4.5" so I can run 160 tyres properly on the track.
Ta
Davo
				Re: 5" rear wheel fitment
				Posted: Fri Jun 20, 2008 5:05 pm
				by abrmoto
				Arh Hah!!!!!
Now I know what you have...........
RGV forum spies are out to get you!!
I know a bigger wheel does go in but cant remeber what its off!! Paul Turner or Graeme France would be able to help.
Graeme is defo worth a call.
Best of luck.
Aly
				Posted: Fri Jun 20, 2008 7:48 pm
				by binge
				CBR600 wheel can be made to fit. Plus it looks the same as the NC29 wheels.
A bit of machine work and some custom spacers and it can be made to fit.
You'll have to run the CBR600 cush drive and sprocket too.
				Posted: Fri Jun 20, 2008 9:06 pm
				by missinNZ
				dont know if your looking for full wide look but  i run a 160 on my standard rims anyway, this was the size on it when i bought and knew nothing of the cbr 400 culture (have since found that it should be 150) but my last three tyres ive stuck with 160
				Posted: Fri Jun 20, 2008 10:23 pm
				by binge
				missinNZ wrote:dont know if your looking for full wide look but  i run a 160 on my standard rims anyway, this was the size on it when i bought and knew nothing of the cbr 400 culture (have since found that it should be 150) but my last three tyres ive stuck with 160
I also run a 160/60 rear on the standard 4.5j rim.
I personally cant tell the difference between a 4.5 and a 5j rim, But ive heard running a 160 on a 4.5j rim can distort the very edge of each side of the tyre, So when at maximum lean it can be a little sketchy.
In fairness I have various parts of the bike touching down before I run out of tyre anyway, So its not a problem. Ive just stuck with 160s because its the size racers use on the NC29 track bikes, so cheap tyres, Plus they look better than the 150s.
				Posted: Fri Jun 20, 2008 10:27 pm
				by sniff
				Hi Dave
I also have the 4.5 and 5 inch they are off the 92 to 98 cbr 600 be aware there is also a 5.5, i got both mine for the combined price of ......£1.98 + £5 postage of fleabay.....happy hunting.....alsoknown as sniff on rgv site)
