Page 1 of 2
Total Cost of a Trackday
Posted: Sat Nov 28, 2009 7:27 am
by Lope
Lets work this out... I'm considering a trackday tomorrow, I'm a bit broke at the moment and wondering what it will cost.
Entrance = R300
1 tank (16L) petrol = R122
Front Brake Pads? = ?
Oil Change = R200 (optional?)
How much do front pads get used on a trackday?
A lot of people change their oil before/after a trackday. How optional is it?
(I run Castrol Magnatec if anyone is wondering... the cheap shit :))
And thats assuming I don't lay it down :) Which I probably wont cos I'll just be pushing myself slightly.
1 GBP = 12.22 ZAR
So far its looking like R422-R622 (35-51 GBP)
Re: Total Cost of a Trackday
Posted: Sat Nov 28, 2009 9:44 am
by Drunkn Munky
A typical trackday in the uk is anything between £35 (winter prices) to £165 (summer prices)
fuel £15-£20
oil change £40
traveling to track £varys a lot depending on location
I'd expect my pads go last a good few full days, same with tyres although I've pretty much shagged at rear tyre on a good day in the summer.
Fun value £priceless :grin:
As for oil Id never use cheap stuff, false econemy in my book.
Posted: Sat Nov 28, 2009 10:49 am
Isnt' magnatec car oil?
Posted: Sat Nov 28, 2009 11:26 am
by Spike16
I find pads dont get rinsed too bad, iv done 5 trackdays and 1 race meeting this year on the same pads I got when I bought my cbr calipers (half used then) aswell as about 2k on the road?
tyres you can get a set of race scrubbed diablo's (if you got a 17" rear) for £50 and they will last your a couple of trackdays (Iv 1 race meeting and 2 more trackdays on a set that had already had three days racing on an sv before)
most people dont swap oil before and after a trackday, its common practise for racing but I never bothered for trackdays, unless its over 9 months old already then swap it
I warn you as soon as you do one you WILL want to do another...and another, thats the true cost of trackdays
Posted: Mon Nov 30, 2009 11:39 pm
by Lope
Neosophist: Castrol Magnatec is a car oil, but a lot of guys on diff types of bikes on the http://www.bikesa.biz/forum" onclick="window.open(this.href);return false; said they've been using it in their bikes, (and its fuckin cheap, R400 for 5l (6.5GBP/l)) so I decided to give it a go. Previously my carbs leaked fuel into my engine diluting my oil which gave me all kinds of issues. (used a bit of oil, fouled plugs, occasional smoke) After sorting my carbs I put in a new batch of CM. Bike is running great now, so it seems like a decent oil at least.
Drunkn Munky: Every time I've done research on oil the outcome has always been the same. "The expensive shit doesn't seem to protect engines any better, its way better to just change the oil more often than use expensive shit". Everyones got a different belief system on oil, thats the one I've adopted :)
Okay, thanks for the tips. So no need to worry about breaks or oil change.
Posted: Tue Dec 01, 2009 12:36 am
I can hardly wait to get the ZXR around the track ;)
Have some SP gear comming from Japan too, hopefully be knocking out mid 70's bhp :) Whens the next dyno day?
RE: Car Oil.
You see, the problem is a motorcycle is a lot harder on the oil than a car is as the motorcycle shares engine oil with the gearbox.
The car oil is cheaper as it doesn't have withstand the sheer force of being in a gearbox and their forumlated differently. Both oils have different additives too.
Years ago, oil was just oil, mineral oil from dino's / fossils etc. Now theres a whole host of wizardry going on with things added etc.
Many people swear by it, and many people have clutch problems, premature cam / gear wear. If you are gonna use auto oil make sure to change it more often (2000km) / 6 months as it'll soon loose its properties.
I cant find the test but car forumalated oil was tested against motorcycle oil and after 1000miles the car oil was a lot 'worse for wear' than the motorcycle oil.
Don't leave it in there till its like sludge and you'll prob be ok, afteall the vfr's old tech now ;)
Posted: Tue Dec 01, 2009 9:27 pm
by Lope
Neosophist: thats interesting. The tests I read comparing synthetic vs non synthetic were on taxi cabs, not motorcycles. On the cabs there was zero difference and in some circumstances the non synthetic even performed marginally better.
So there could be a point there about running motorcycle oil on a motorcycle.
I'd like to see the test if u can find it.
Posted: Wed Dec 02, 2009 1:27 am
Lope wrote:Neosophist: thats interesting. The tests I read comparing synthetic vs non synthetic were on taxi cabs, not motorcycles. On the cabs there was zero difference and in some circumstances the non synthetic even performed marginally better.
That test isn't really relavant though.. as your testing two types of car oil in a car, they also make synthetic oil for a car.
Though 4-cycle motorcycle engines may be considered more similar to automobile engines than 2-stroke motorcycle engines, they still have very different performance requirements. Historically, 4-stroke motorcycles have had problems with gear pitting wear in the transmissions and clutch slippage. In many cases, this can be directly attributed to the oil used. Most automotive engine oil is developed to minimize friction and maximize fuel economy. Since the oil for many 4-stroke motorcycles is circulated not only through the engine [as with an automobile], but also through the transmission and clutch, different characteristics are required of the oil. First, a certain amount of friction is necessary to prevent clutch slippage. Second, the oil needs to prevent wear and pitting in the gears of the transmission. These and other essential characteristics are addressed in the standards developed by JASO for 4-stroke engines.
As with the 2-stroke classification, the JASO 4-stroke classification is also divided into grades, MA and MB. MB is lower friction oil, while MA is relatively higher friction oil. Other than friction, the JASO 4-stroke classification tests for five other physicochemical properties: sulfated ash, evaporative loss, foaming tendency, shear stability, and high temperature high shear viscosity (HTHS). Sulfated ash can cause pre-ignition if the oil is present in the combustion chamber. It can also contribute to deposits above the piston rings and subsequent valve leakage. Evaporative loss and foaming reduce the amount of lubrication and protection in the transmission, engine, and clutch. With less shear stability, oil loses its capability of retaining original viscosity resulting in increased metal-to-metal contact and wear. High temperature high shear viscosity tests provide viscosity characteristics and data under severe temperature and shear environments.
A simple explanation from Mobile1.com
Answer:
Motorcycle oils and passenger car oils are very similar, with the exception of a couple of areas that are key to motorcycle operation. The first area concerns common sumps, or the use of motor oil, to lubricate and cool the transmission. As you know, in a passenger car the transmission is lubricated by an ATF fluid, which has frictional properties required for transmission operation. In a motorcycle, where the transmission may be lubricated by the engine oil, an engine oil that does not have the same level of friction modification (for fuel economy) of a typical passenger car engine oil will provide better transmission performance in terms of transmission lock-up and slippage. So motorcycle engine oil does not contain the friction modifiers of a passenger car engine oil. The second area of concern for motorcycle engine oils is that they tend to shear (breakdown viscosity) more quickly than a typical passenger car. Mobil 1 motorcycle oils are designed to provide exceptional protection against viscosity loss.
Basically, your car oils have 'friction modifiers' in them, these make the oil more slippy and improve fuel economy... most motorcycles have a wet-clutch that runs in the oil, these need a certain amount of friction else they slip with too much torque, car oil tends to make the clutches slip / wear out prematurly.
The second problem is the gearbox is very harsh on engine oil.. it sheers a lot of the additives added to car oil reducing the viscosity.. 10w40 becomes 10w30 in 1000 miles in some cases.
Just search the net for car oil in motorcycle, theres loads information about it.
A friend from a bikers club ran mobil1 in his VF750 interceptor for years telling me motorcycle oil is a 'waste of money'
His clutch, transmission and cams are all now badly worn and the bikes done half the miles as one of my VFR's. :P He's not one to slack off on maintainance either so I dont think its just co-incidence.
Modern bikes are quite sophisticated, it's like me putting red diesel in a modern engine.. sure it'll run for a while but when the engine becomes all sooted up and brakes down i'll know why!
Posted: Wed Dec 02, 2009 1:40 am
by Lope
Very Interesting Points. On the bikesa forums they basically said "a bunch of us use it, the clutch doesn't slip, so its fine" haha.
When this car oil is done I'll stick with MC oil :)
Posted: Wed Dec 02, 2009 1:43 am
Lope wrote:Very Interesting Points. On the bikesa forums they basically said "a bunch of us use it, the clutch doesn't slip, so its fine" haha.
Somtimes you will not have clutch problems!
The other things to consider like the oil wearing out quicker etc is somethign you'll have to decide on.. many people do use it and some don't have any problems.. but is the saving worth buying new engine parts should something bad happen.
So long as its changed regularly I don't really see too much of a problem with an old vfr.
