Shims
				givenchy
- Bike owned: GSXR400 GK76A
Shims
Can someone advice on the acceptable kilometres the bike can do before the shims/valve clearence can be adjusted again!? Can you also please confirm the acceptable clearence. My question is based on the fact that the bike struggles to start once they are out of spec.
- Variablevalves suck
Re: Shims
Its about every 6000Km's and the link will cover everthing else.
http://www.400greybike.info/newforum/vi ... =53&t=6748" onclick="window.open(this.href);return false;
Re: Shims
Ye not long, but when you think the engine is above 10000rpm most of the time you have to feel sorry for the little girl. The service is very easy as you only got to push the followr over and after swopping shims around you usualy only need 4 or 5 new ones.
				patrick
Re: Shims
 hey there
 hey therei cant tell u on what kilos the shimming should be done but i can give u the corect clearence of the shimming.
Valve clearance intake: 0.10-0.15 on a cold motor
Valve clearance outlet: 0.15-0.20 on a cold motor
That is the specs acording to the book..
Hope u come right
Patrick
