nc30 screen brace
Posted: Thu Nov 19, 2009 9:52 pm
by pugparcels
just a thought after working a bit more on the bike tonight, as i have used cbr 600rr fairings and removed the screen brace as this is no longer required, i have found the front end lock to lock the switch gear ( indicator / high low beam side ) touches the tank only slightly but it does touch.
does the original screen brace stop the yoke turning this far causing the switch gears to touch? i am more think for mot purposes.
chris
Re: nc30 screen brace
Posted: Fri Nov 20, 2009 6:18 pm
by banoffee
nope. mine hits the lock stops on the bottom yoke / frame only. everything else *just* clears.
Posted: Sat Nov 21, 2009 6:40 pm
by mick.mh2racing
My clutch lever hits the clocks but I have it set low. I've had to lift it before now for MOT time.
Posted: Sun Nov 22, 2009 12:46 pm
by pugparcels
cheers for the replies, will have another check when put the front end back together. it only just touches and i have only noticed when the front end is up in the air, both clipons are straight so will have another check.
i have had issues with levers touching but that is due to the mix of 954 master cyclinder, rrv fireblade clocks & cbr 600rr front fairing all mounted on a nc30!
i will hopefully have it all sorted soon
Posted: Sun Nov 22, 2009 1:09 pm
by banoffee
I also noticed there is a very small range of adjustment on the standard clipons where they locate in the top yoke. When I first got my bike the LH one got too close to the tank on full lock. I set both to 'furthest forward' and had no probs since.
Posted: Sun Nov 22, 2009 3:25 pm
by pugparcels
thanks will check that as well
Posted: Tue Nov 24, 2009 12:08 pm
by pugparcels
Cheers banoffee, have put the front end back together and fount the left hand clip on was not seated properly first time around. only by a bit but enough to cause issues.
Thanks again.
Posted: Tue Nov 24, 2009 12:57 pm
by banoffee
