Front calipers vfr 400
Posted: Sun Oct 25, 2009 6:52 pm
by rider4life
Do calipers from vtr 1000 sp2 fit straight on the vfr with no mods ?
Re: Front calipers vfr 400
Posted: Sun Oct 25, 2009 8:49 pm
by neurosyndrome
I don't think so...
Are they the same than SP1's ??
You'll need a mounting kit. Rick Oliver sells some
http://www.rvf.dk/rickoliver/" onclick="window.open(this.href);return false;
I quote : "Brake caliper mounting kits - NC30 forks/SP1(CBR600RR/Fireblade) calipers"
Cheers,
Posted: Sun Oct 25, 2009 8:59 pm
by DanHam
I like the sound of this, bit of a noobish Q but will they work with my VFR Galfer discs?
Posted: Sun Oct 25, 2009 9:31 pm
DanHam wrote:I like the sound of this, bit of a noobish Q but will they work with my VFR Galfer discs?
Damn been answered.
I can't recall but are the SP2 calipers different to the SP1?
Either way you'll need brackets making up. If they are the same mounting as the SP1 then
Fortuantly the SP1 CBR600RR calipers have adapters made up for them by Mr Rick O.
They just move the caliper to the point where it can be mounted
You can use your standard disc.
Posted: Mon Oct 26, 2009 1:44 am
by Cammo
SP1 and SP2 calipers are the same, and same fitment as 2003-4 cbr600rr.
I recently got some caliper adapters from Rick O, very impressed with the machining quality as usual.
Posted: Tue Oct 27, 2009 4:35 pm
by micpec
There is also a possibility to fit Brembo's 65mm calipers on the NC30 (using alloy brackets).
If interested, I do have a complete Brembo set that will be for sale soon.
Posted: Tue Oct 27, 2009 4:52 pm
by pugparcels
maybe worth noting, if you cahneg the calipers to sp1/fireblade calipers with the rick oliver brackets your existing brake hoses wont be long enough.
