Howdy
Posted: Sat Oct 17, 2009 9:11 pm
by Indiana Jones
Been reading here for a while.
In the process of getting my NC30/35 hybrid ready for the track.
Was last raced and crashed by me in '05.
So far I've got the front end refreshed and resprung,replaced the calipers, as the bleed nipples were seized.
A GSXR K8 radial m/c.
It was jetted and running fine with free flowing air filter,would like to do more with the airbox and jetting.
Removed the generator,not sure about removing the flywheel, as I believe torque will suffer???
Stripped down harness.
NC35 rear linkage,rear wheel.
I have a Sachs RS250 shock with adjustable ride height that I need a spring for(900lbs/175lb rider),does it need to be revalved to slow it down?
I really want the HRC CDI on ebay,is the Rick Oliver unit comparable?
I need some new body work, ebay again,front faring for 120 pounds.
The motor was freshened up in '04 with new rings and refreshed heads.
I just need some direction and hope.
http://www.youtube.com/watch?v=WiFVAC8zJbc" onclick="window.open(this.href);return false;
Great site,brilliant information.
Re: Howdy
Posted: Sat Oct 17, 2009 9:20 pm
indiaguy wrote:Been reading here for a while.
You'll probably destroy the engine if you try to run it without a flywheel. The flywheel acts as a counterbalance for the engine.
You can change it to a lighter weight flywheel, which will have pro's and cons.
It won't give you any more HP but it will affect how the bike accellerates and rides. As a general rule of thumb, the lighter the flywheel the 'twitchier' the bike will be.
I know some of the smaller bikes actually add weight to their flywheels!
Theres a few people here that have a lighter flywheel so they can comment on how its affected their engine.
Re: Howdy
Posted: Sat Oct 17, 2009 9:29 pm
by Riley
If you are running an Rvf engine/loom I have an genuine Rvf Hrc cdi for sale - just put up and advert in the for sale section.
Re: Howdy
Posted: Sat Oct 17, 2009 9:50 pm
by Indiana Jones
Thing is,not sure what loom/CDI, is on it.
Would the RVF motor run with the VFR loom and CDI?
If so,could I plug in the RVF cdi?
Is the connection different?
Re: Howdy
Posted: Sun Oct 18, 2009 8:49 pm
by Indiana Jones
It's a VFR loom and CDI.
Is the Rick Oliver CDI comparable to the HRC unit?
Certainly less expensive....
Re: Howdy
Posted: Mon Oct 19, 2009 10:51 pm
indiaguy wrote:It's a VFR loom and CDI.
Send a PM to Rick Oliver! He uses this board a lot
Re: Howdy
Posted: Tue Oct 20, 2009 10:05 am
by banoffee
don't know if it's comparable but I have one with the HRC map on it and am pleased with it
