Page 1 of 2
Programmble ecu cdi
Posted: Fri May 02, 2008 11:30 am
by mruehl34
Can some tell me the difference between the cdi from
chrisxr750 and the rtd ecu. I think abr use the rtd.
Can someone help me.
Michael
Re: Programmble ecu cdi
Posted: Fri May 02, 2008 9:24 pm
by chrisxr
the rtd ignitions cost around £500, they have to be wired into the system i personly have no experience with them as i couldnt afford one, they have a few extra featurs over mine, they use variable maps done via potentiometer and can be programed to adjust coil energise time, my units plug straight into your loom, if you pay a little extra i can supply ones with throttle pstion sensor and variable map which will give you a crude form of 3d mapping but i dont see its relevancy for racing purposes or such a small engine. mine have 2 year warranty and are made from quality components............................................
Posted: Fri May 02, 2008 9:32 pm
by mruehl34
OK i understand
you will get a mail.
Michael
Posted: Sat May 03, 2008 7:33 am
by lee_
chrisxr, is this an ecu you have produced yourself then?
Posted: Sat May 03, 2008 7:53 am
by dave moffitt
can vouch for chris's cdi :D .
last weekend i broke the course race record at jurby,the midrange and topend have been improved with the base setting on a well used motor:lol:
lots more to come with fresh motor
and off to northwest200 with it.Shall be interesting to compare with last years speeds
keep it a secret though
Posted: Mon May 05, 2008 10:55 am
by mruehl34
pm send.
Michael
Posted: Mon May 05, 2008 1:23 pm
by chrisxr
lee_ wrote:chrisxr, is this an ecu you have produced yourself then?
I have worked with a company to get these units designed for these bikes and other models, i am representing these in the uk and covering the warranty and setup. I personaly havnt produced these, they are made by a reputable electronics firm.
Posted: Mon May 05, 2008 1:36 pm
by chrisxr
dave for north west dont run final rev limit higher than 14900 think its set at 14700 when left me i think you can go a alittle more on that if you have a good valve to piston clearence, a extra 400 rpm over the hrc ignitor will give you a great slip stream aid at them long northwest straights. Did find now dave that if running motors with higher compression the timing needs retarding i have a map for a well preped 72hp motor did the other day and the figures are a little different than the one for stock compression, mail me i will send you a programe of that map we spent a whole day getting this one but you may have to do a little re jetting when done as it leans your fueling a little.
I want to go watch the north west but its not gonna happend ........... will they be covering it live via pc again?
Posted: Mon May 05, 2008 7:58 pm
by leon
can i have a copy of that map aswell please
Posted: Mon May 26, 2008 9:26 pm
by danh
dave , how did you get on at the NW? coverage of the 400/125 class was pretty poor...
im interested in the cdi upgrade and have PM'd chris...did your bike pull well down to university..and how was it compared to the SV's? what were your speed trap times like, better than last year?
did you get some before and after dyno data for the cdi mod..?
dan :D
