Page 1 of 2
VFR shock into a CBR
Posted: Mon Oct 05, 2009 6:08 pm
by viper_biker
OK, we know you can retro fit a Firblade shock into a VFR, but what about the other way? Rather than sell my Hyper-Pro I'd like to fit it into the 'Blade.
For those of you running aftermarket Fireblade shocks in their VFR, what did you have to do to make it fit?
Re: VFR shock into a CBR
Posted: Wed Oct 07, 2009 12:35 pm
by viper_biker
Anyone know?
I'm going to mail Hyper-Pro today and see if they can do it for me, if not then I'll sell it and get one for the CBR.
Posted: Thu Oct 08, 2009 9:11 am
by viper_biker
I guess it's a no then,
Hyperpro wrote:
Gareth,
In principle this is possible.
However: we would need to change the Tube, Spring, Spindle and Setting of the shock.
These parts, combined with the hrs of work and shipping, makes such a conversion more expensive then buying a new one, especially if you count in the money you would recieve if you would sell your current VFR400 shock.
Unfortunatly, the bike manufacturers make every bike a little different, which means a different shock for each bike.
We would really like it if they were more the same, so you could exchange shocks (and it would save us a lot in development), but this isn't the case unfortunatly.
With kind regards,
John Troost
Posted: Thu Oct 08, 2009 9:32 am
by Cammo
Hmmm, no good.
At the least I would say you would need to fit a new spring (you could confirm this by looking at the standard spring rates of the 2 bikes, the linkage differences might put them way out
I still wouldn't eliminate it fitting though. The spindle might just need some slight mods. Only way you'll be able to tell for sure is to measure you blades shock.
I reckon it will (or could be made to) fit fairly easily. But then I'm an optimist, and have been proven wrong with bleeding knuckles and profanities in the past in efforts to try and prove it...
Posted: Thu Oct 08, 2009 12:20 pm
by viper_biker
I too have those scuffed knuckles and said a bad word or 2 in the past, but I now like to remove, fit then forget. I guess by selling the Hyperpro it'll free up a few quid to throw at the CBR's arse.
Posted: Fri Oct 09, 2009 11:10 am
by brido
How much are you looking for your hyper pro shock if your going to sell it?
Posted: Fri Oct 09, 2009 1:12 pm
by viper_biker
It's for sale at £450. Where abouts in N.I. are you? I can even fit it for you if you like.
Posted: Fri Oct 09, 2009 5:57 pm
by brido
I'm in glengormley, what weight of rider is it set up for? and how old is it? just a wee bit of info on it? You could check my valve clearances as well if you like
Posted: Fri Oct 09, 2009 6:22 pm
by viper_biker
I'm 13 stone, so about that weight. The date on the reciept it November 2005, but the shock hasn't seen that many miles though. What do you want to know about it. It's an all-singing, all-dancing top of the line piece of kit. Compression, pre-load and re-bound. High speed and low speed damping on a remote reservoir. The best improvement you'll ever do to your VFR/RVF FACT. Will be available from Sunday onwards.
Valves unfortunately need to be done when the motor is stone cold and sat at least overnight.
Posted: Fri Oct 09, 2009 7:17 pm
by brido
Whereabouts are you?
