potential earthing problem
Posted: Fri Oct 02, 2009 7:04 pm
My NC30 runs great when it wants to but doesn't like starting.
I have followed the electrical testing guide on here for regulator/rectifier problems and found it was the battery not holding charge. With a new battery freshly charged by the optimate4 it starts and runs fine. If its been on charge Friday night it will start on the button until about wednesday at which point it will start then conk out, starter motor spins up but it needs a bump to get running. By Friday morning its stone cold dead. The reg/rec is still working correct according to the haynes and guide so I assume the alternator must be ok. most trips are 26 miles around with the lights on, could it be I am just not doing enough to charge the battery?
I have tested the battery today (friday after charging it last weekend) and its steady at 11.70v enough to spin the starter but not kick into life. If i put one sensor on the red+ battery terminal and the other on the kick stand I get a reading of 11.70v should this happen or does this mean I am leaking power into the ground? I don't have a rubber foot for the kick stand.
anyone got any ideas?
