engines goin back in!!!
Posted: Fri Jun 13, 2008 8:40 pm
by yayoboy
hi all, puttin the lump back in 2morrow mornin, just couple of question on
a) any1 got any pics of the way the loom runs round the engine & frame
b) what bolts go where + spacers
im pretty 'sure' of where it all goes + iv got me haynes but as its critical i thawt id ask just 2 be 100%
thanks, sean
Re: engines goin back in!!!
Posted: Fri Jun 13, 2008 8:56 pm
by graybriggs
For what bolts and spacers to use look here:
http://www.akhara.com/nc30/nc30parts/files/49.htm !
Remember that the lower right mounting bolt goes in first then the engine then the adjuster bolt threads through the mounting bolt then through the frame through a washer/spacer then the engine and nut goes on other other side. Castle nut goes over adjuster bolt. Caking the mounting bolt and adjuster bolt in grease helps a lot. My adjuster bolt got very very (very!) tight going in.
Hope yours fares better!
Left Front: 10x40
Left Middle: 10x50 + the biggest spacer
Left Rear: 10x35
Left lower: nut over engine mounting bolt
Right Front: 10x40 + thin spacer
Right upper/middle: funny adjuster-like bolt + 10x60 + Castle nut
Right middle: 10x40 + big spacer
Right lower: is the adjuster + mounting bolt then castle nut (don't forget a spacer/washer goes on the inside of the frame it's number 18 in the diagram)
Think that is everything for the main important bolts.
Lots of edits this evening
Posted: Fri Jun 13, 2008 8:58 pm
by yayoboy
or could some1 edit this roughly to show the loom?
Posted: Fri Jun 13, 2008 10:05 pm
by RVFHooligan
I've got pics at home, I'll post them later after work.
Posted: Fri Jun 13, 2008 10:21 pm
by yayoboy
thanks gray, spot on m8 :D , thanks jeff :D
Posted: Sat Jun 14, 2008 12:10 am
by hannakournikova
it goes up below the front frame mount and round towards the headstock. so bassically on the outside. hope this helps.
Posted: Sat Jun 14, 2008 12:37 am
by RVFHooligan
Posted: Sat Jun 14, 2008 8:34 am
by yayoboy
spot on pics, great help, thanks jeff :D
Posted: Sat Jun 14, 2008 9:01 am
by yayoboy
thanks hanna 2 :D
Posted: Sat Jun 14, 2008 4:50 pm
by yayoboy
engine went in a treat no probs at all, loom looks pretty straight 4 ward now 2, thanks all!!! :D :D :D
