				Wot are the 2 12mm bolts just below the stator cover/caseing
				Posted: Mon Sep 14, 2009 3:25 pm
				by tiptop
				As title wot are the 2x 12mm bolts just below the stator caseing for?
				Re: Wot are the 2 12mm bolts just below the stator cover/caseing
				Posted: Mon Sep 14, 2009 3:27 pm
				by tiptop
				for got 2 say its on a 3TJ engine im talking about.
				Posted: Mon Sep 14, 2009 9:25 pm
				by Evilchicken0
Not sure where you mean
				Posted: Mon Sep 14, 2009 9:44 pm
				by tiptop
				the other side i thought it was the stator casing it was called? maby not be anyway just be low is ther are 2x 12mm bolts about an inch or 2 apart from each other just wondering wot they are?
				Posted: Tue Sep 15, 2009 3:31 pm
				by Evilchicken0
I think it splits the crankcases - they're top and bottom on this engine
				Posted: Tue Sep 15, 2009 7:56 pm
				by tiptop
				ok no problem thanks.i think i have we slight oil leak from 1 of mind so was going 2 take them off and put some new copper washers on them but just wanted 2 no wot was going 2 come out of them which will probley just be the engine oil that comes up 2 that level of the engine.
also see that we bracket bolted onto the bottom of your engine is that fairing mount bracket?
				Posted: Tue Sep 15, 2009 9:17 pm
				by Evilchicken0
				The triangular one ???
Yes it has a captive nut that clips onto it and the bottom of the fairing bolts into it.
				Posted: Tue Sep 15, 2009 9:22 pm
				by tiptop
				aye thats the one
