fuel leaking into carb then onto ground
Posted: Mon Sep 14, 2009 12:44 pm
as title suggests,
i started up my trackbike the yesturday just to keep things going between race meets.
started fine, revved smooth and everything seemed O.K. i shut the bike off and go inside, i go out to the shed about 1 hr later and the smell of fresh unburnt fuel hits me,,,,, WTF. i look in the belly pan and theres fuel in there, i take the drain plug out and a fair bit of fuel comes out, about 100ml.
i turn the tap off and go inside, planning on working on it today.
i get to the bike today and started it, started fine and everything seemed normal, turned tap on and still everything sweet. so i shut her off and went inside, again going out in and hour and same thing, about 100mls of fuel in the belly.
so i took off all the body work and fuel tank to have a look at whats going on, it seems that the front left (whilst sitting on the bike) carb is leaking fuel into the intake. Being pot luck the inlet valve must be shut so not alot of fuel, if any, is going in the engine instead going on floor. not all bad i guess
am i right in thinking i need to give the float seat a clean and inspect its seal??? as this is a pain in the ass as i usually leave the tap in the ON position and its never been a problem.
or should i leave it alone and just turn the tap off between runs and hope it clears itself
as i have just had it dynod and i dont want to mess up the settings
cheers guys
cheers guys
