NC23 stalling at tickover with the headlights on?
Posted: Sun Sep 06, 2009 9:24 am
Hiya!
Will run fine with the sidelights on, with headlights on if stopped at - say a roundabout, the engine will flutter then die - if the starter is pressed the engine will spin but fail to catch until the lights are switched off?
The only thing I can think that is different is one of the headlight bulbs is a H4 55/60w car type instead of the standard H1 Jap 30/60w bulb? The LBS didnt have any H1 bulbs and like me - had never even seen one! They could get one in but it would cost £12.57... I elected for getting a H4 and breaking the two lower tabs off...
Personally I wouldnt have thought the extra 25w wouldnt have made that much difference? I may try pulling the plug off of one bulb and seeing if that makes a difference? (obvoiusly just around town...)
Battery & starting are fine otherwise, just the stalling prob when stopping? Tickover is set slightly high at 1500rpm...
Any ideas?
Any ideas?
