CRM's NC30 project - codename EXON VALDEZ
Posted: Sun Aug 09, 2009 5:51 pm
Purchased said piece of shit from a localish chap with the intention of building a bike i can use on those not so nice days, not worry about scratching or getting damaged, and just enjoy riding regardless of what it looks like.
Found this piece of shit from a guy on here advertised as an abandoned project, no time to finish, you know the score. However its certainly been used and used in anger and bodged no end. Infact someone must have been an iron monger as the bolts were from some random shelf, to long, infact so bodged the only redeeming feature is the fact the engine cases appear untouched so no monkeys been inside it hopefully. No V5, never registered so needs a frame then.
took a chance and had it collected blind and for the vast sum of £300 stirling (at todays exchange rate to the euro that will be fuck all then) and i thought "a NC30 for 300 quid, got to be worth a chance"
So bike was dropped off and i started to go through it trying to get a list together of whats needed.
Within 5 mins i quickly worked out to mark out what was useable which was quicker.
Bodywork and tank = scrap
rearsets = scrap
pedals = scrap
clocks = scrap
left hand clipon and all switchgear = scrap
headlamps = scrap
loom = scrap
battery = scrap
lockset = scrap
Hub = scrap
Levers = scrap
Carbs = proper fucked
Rads = go on have a guess
All fairing mounts and brackets = missing
Frame = sourced
Swingarm = useable
Shock = got a maxton
Forks = got a set
Engine = its there
Exhaust = got a yamamoto
Rads = got a spare set
Wheels = Got a set with tyres
Chain and sprockets = need
Bodykit = got almost a full 89 RWB need V panel and mudgaurd
Lockset = need
Battery = Need
So after finally looking at it for 5 weeks and realising it aint going to build itself, i today started to strip the POS and evict the spider colony from under the seat unit.
So here it is, next free day i get will be to remove the engine and clean it before putting in the new frame.
rearsets = scrap
pedals = scrap
clocks = scrap
headlamps = scrap
loom = scrap
battery = scrap
lockset = scrap
Hub = scrap
Levers = scrap
Frame = sourced
Swingarm = useable
Forks = got a set
Engine = its there
Lockset = need
Battery = Need
