				vfr not running properly any help please
				Posted: Thu Aug 06, 2009 2:10 pm
				by Vfr400nc30
				my honda vfr 400 nc 30
is not running properly when the petrol is on it dies as if it has run out of petrol
so i am running it on resevers and its going fine
any thoughts please
thanks
				Re: vfr not running properly any help please
				Posted: Thu Aug 06, 2009 9:44 pm
				There are two tubes of different lengths for main and reserve in the tank.  Sounds like your long one for main is blocked..
That's my 10p guess anyways
Welcome to the site too..
				Posted: Thu Aug 06, 2009 9:55 pm
				by dunkenb
				could be the vacuum diaphram in your fuel tap has worn out or has a pin hole in it which stops it working, think it's by passed when you use reserve!
				Posted: Fri Aug 07, 2009 9:04 am
				by Vfr400nc30
				CMSMJ1 wrote:There are two tubes of different lengths for main and reserve in the tank. Sounds like your long one for main is blocked..
any idea how i get a pipe unblocked? And thanks for the help.
				Posted: Fri Aug 07, 2009 11:09 am
				by Cammo
				You need to take the petrol tank off (turn the tap to off, remove the top breather hose, then hoses from the fuel tap), then remove the fuel tap - it's fastened to the underside of the tank with 2 bolts.
When you have it removed you'll see the 2 tubes.
