Little help required (NC24) please?
				Terri400
 - Bike owned: NC24
Hi Guys
Bit of assistance with NC24 required, does anyone here have an original toolkit with their bike? They’re missing from both of our bikes and I’d like to put something like the original back on them. Photographs or written descriptions all welcome.
Secondly, the fairing fixing to the rear side fairing panels, the large spring loaded jobbie that’s a push and 900 twist, I presume that they are a rare as rocking horse poo and I’ve not seen them on e-bay DSS or Wemoto, any thoughts as to where they might be available?
Ian
Ian
				fastdruid
Re: Little help required (NC24) please?
At a guess the tool kit will be similar to the NC30 one http://www.bike-parts.fr/pieces-option- ... -1991.html" onclick="window.open(this.href);return false;
As for the what I presume is a Dzus google Dzus or try david silver spares maybe?
Druid
Druid
				Terri400
 - Bike owned: NC24
It probably will be similar Druid, but there again the hub/swing arm adjustment is completely different, so the adjustment tool (actually an allen key does it) will at least be different.fastdruid wrote:At a guess the tool kit will be similar to the NC30 one http://www.bike-parts.fr/pieces-option- ... -1991.html" onclick="window.open(this.href);return false;
I'm confident it's not a Dzus fastener mate, it's a really big plastic spring loaded jobbie, I know this as the one I did have has fallen out and lost itselffastdruid wrote:As for the what I presume is a Dzus google Dzus or try david silver spares maybe?
Druid
Ian
				nemesis
 - Bike owned: Nc21, NC24, FZR750, FZR1000
Iff your on about the big 1/4 turn fastners that hold the side panel on , I got 2 last year from the local honda shop.
Think they were about £5 each tho
- paul nc 24
 - Bike owned: 2000 R1
http://www.elliottmc.co.uk/welcome/about" onclick="window.open(this.href);return false;
give these a try got quite a bit of nc24 gear(and they list the parts you want) but sssshhhh! dont tell anyone or all the stock will go.
as for the tool kit i will post the parts manual page for you when i can. thats a basic drawing listing all honda part numbers
cheers paul
cheers paul
There not rare at all. David Silvers and Lings have them both instock.. you'll have to buy all 4 parts separatly, there about £5 for all 4 piecesTerri400 wrote:Hi Guys
Ian
As for the tool kit, most honda kits are the same, apart from the C spanner that you use to adjust the swingarm with.. get a kit off a new fireblade for cheap and just buy the C spannner.
The plastic fairing bolts...
83703-ML0-720 x 2 (Plastic Bolt)
17516-383-670 x 2 (The spring)
94101-10000 x 2 (The Washer)
94305-20183 x 2 (The Pin)
The toolkit.
Bigger image @ http://www.jacksons-lair.co.uk/nc24xx/P1020775.JPG" onclick="window.open(this.href);return false;
hope that helps
				Terri400
 - Bike owned: NC24
Thanks all, especially Neo, I'll sort the fixings from DSS now I have the part numbers.  The tool kit I'll get put together too, most bit there seem farly obvious, but can anyone tell me what 2, 3, 4, and 15 are, 'fraid I don't read Japanese.
Ian
Ian
Part #2 is a 10mm Box SpannerTerri400 wrote:Thanks all, especially Neo, I'll sort the fixings from DSS now I have the part numbers. The tool kit I'll get put together too, most bit there seem farly obvious, but can anyone tell me what 2, 3, 4, and 15 are, 'fraid I don't read Japanese.
Ian
Part #3 is a 16mm Plug Spanner
Part #4 is a 17/19mm Socket Spanner for the rear wheel nuts.
Part #15 is a spanner handle (Spanners #16 and #17 fit into it for extra leverage:)
				Terri400
 - Bike owned: NC24
[quote="NeosophistPart #2 is a 10mm Box Spanner
Part #15 is a spanner handle (Spanners #16 and #17 fit into it for extra leverage:)[/quote]
That simple eh
  Drawing don't turn readily into micro-fiches do they.  Thanks again though Neo
Ian
That simple eh
Ian
I have started scanning the parts book but it takes a while. I'll put it on my site when i'm done.
if you do need to know any parts in the mean time just ask :)
