NC30 Dog bone Mod, Urgent!!!!!
Posted: Tue Jul 28, 2009 10:34 am
by Spike16
Urgently need, tried doing a search but not much found
how far down the original dog bone should I drill the new hole?
need to do this today as Il hopefully be at oulton tomorrow and dont want to be decking the fairing out again
Re: NC30 Dog bone Mod, Urgent!!!!!
Posted: Tue Jul 28, 2009 10:38 am
mate, seeing as it is my fault due to lack of postage skills... I'll post these pics for you.
Cammo knows the answer>> My recall is that it is 8mm? You end up with a slot rather than 2 seperate holes.
Hope this helps dude..
Posted: Tue Jul 28, 2009 10:46 am
by Spike16
slot? shit so wont the dogbone move about in the slot?
got a pic of a modded one
Posted: Tue Jul 28, 2009 10:59 am
by Cammo
CMSMJ1 wrote:Cammo knows the answer>> My recall is that it is 8mm? You end up with a slot rather than 2 seperate holes.
Who me?!
8mm is correct.
You do end up with a slot. Best to weld up the old hole and drill a new as they do overlap a smidge.
Posted: Tue Jul 28, 2009 11:04 am
by Spike16
no time to weld, is it ok to run with this slot? or will the triangle thing move about in the slot
Posted: Tue Jul 28, 2009 11:24 am
by hunter
This what you want spike,
http://www.400greybike.info/newforum/vi ... =24&t=5346" onclick="window.open(this.href);return false;
Posted: Tue Jul 28, 2009 11:32 am
If you imagine drilling 8mm from the centre of the original hole you'll get a hole with one edge missing (form the other hole)
It "may" be fine, as I am sure that only a few people have welded it up. If you want, you could go for a 10mm hole for even more ride height..and avoid drilling into the other hole.
I have no pics to hand..I'll see if I can find one.
@ Stickshift..yeah you!
Posted: Tue Jul 28, 2009 9:46 pm
by Spike16
no time, Iv adjusted the chain so its giving max ride height but not drilled dog bone
Posted: Tue Jul 28, 2009 10:56 pm
by Cammo
Spike, try and get it done for next time out.
It changes the handling for the better and also the shock if you have a standard one. In standard form nc30's drag their arse way to low to the ground for decent tip in on the track.
