Page 1 of 2
Anyone running without brake pad springs?
Posted: Thu Jul 16, 2009 12:22 am
by Cammo
Righto, this question is mainly aimed at racers or dedicated track bikes.
I can't see any advantage in having pad springs in the front calipers, and the disadvantage that they just create friction on the pads and less feel when being used.
The rc30 kit manual recommends removing them from standard calipers, I thought I might do this as I've been having a few caliper dramas lately (which are resolved now).
Does anyone run with them removed??
Re: Anyone running without brake pad springs?
Posted: Thu Jul 16, 2009 2:24 am
by zimm
I dont use the spring things on my zxr calipers, just lockwire the pins instead of using the OE "R" clip
brake feel is improved, fade reduced and pad/caliper removal/fitting is easier
Posted: Thu Jul 16, 2009 3:23 am
by Cammo
That's confirmed my thoughts Zimm, thanks.
Posted: Thu Jul 16, 2009 7:43 am
by RonniB
I don't use them either, it seems to allow the pads to sit more freely in the retracted position. Likewise I have removed the dustcovers too, to allow more cooling air to travel past the pads.
Ronni
Posted: Thu Jul 16, 2009 9:02 am
by Biff
+1....
Posted: Thu Jul 16, 2009 12:00 pm
by Martin
Stickshift wrote:Righto, this question is mainly aimed at racers or dedicated track bikes.
Cam, that's exactly what I've done and where I got the idea from. Took the dust covers off also to cool pads and let the dust blow out rather than collect in the calipers as I've also removed the dust seals.
Here's a question, do RC30 calipers fit NC30 forks? If so I think that means we can stick RS250 calipers straight on as they are the same as the kit RC30 calipers if I'm right, mmmmmmmmmm.
Posted: Thu Jul 16, 2009 2:28 pm
by Spike16
anyone got a pic of these pad springs? (what are they)
my cbr600 ca;ipers just have piston ont pads (no metal backing thing) onto disk and an ally plate at th etop that goes were the pins hold it, is that what your on about?
Posted: Thu Jul 16, 2009 10:21 pm
by Cammo
Yes, I believe they do.
You can pick up rs250 calipers pretty easily off yaoo japan, but they're a bit pricey.
Posted: Thu Jul 16, 2009 10:23 pm
by Cammo
Yep it's this single alloy plate that sits on top of both pads spike.
Posted: Thu Jul 16, 2009 11:54 pm
by Spike16
hmm whats the advantage of taking these off? my pads dont release too well (you can hear them rubbing on the disk when moving th ebike about the garage) will taking these off help?
whats the disadvantage do this (ie why are they their in the first place)
