xivlia's thread of nc30 problems and questions
Where posts and threads can be moved to future safe keeping.
Locked
porndoguk
Re: xivlia's thread of nc30 problems and questions
Post by porndoguk »
We're there :D
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
:blowout: :blowout: :blowout: :blowout: :blowout: :blowout:
Deviants AM/PM build
viewtopic.php?f=62&t=27307
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
OKay, i removed my carbs and as you can see one of the cylinders are full of petrol. i removed all my plugs, only the one with the petrol is soaked, the other plugs are dry.
how do i drain this? do i just leave it to evaporate. and i still havent drained that dirty oil in the bike yet, my dad took most of my tools away :(
oh and also as you can see the cogs and all that stuff is dry, there is not even a trace of oil or lubrication on them.
porndoguk
Post by porndoguk »
If its been stood then the oil (thin petrol soaked oil) will drain down to the sump,
force-v4
Bike owned: Far too many now!
Post by force-v4 »
Get your self a syringe mate & suck the fuel out.
Or alt. turn the engine over by hand to release it into the engine & then drain it with the oil.
I would say, the syringe would be the better option though.
& also, just give the cylinder head internals a little squirt of something to lube it up.
xivlia
Post by xivlia »
ah okay, well ive managed to find some tools and drained the oil. i have a large syringe i could use that. but would that get rid of all the petrol? isnt there more right into the cylinder chamber?
Delboy
Post by Delboy »
I've always found that the best way to remove any excess petrol is to use a blow torch, always worked for me...lost a few eye brows along the way though :lol:
force-v4
Post by force-v4 »
If you're draining, then, as I say, turn the engine over by hand, so via the side case timing gear, this will open the valves & release the fuel into the engine.
xivlia
Post by xivlia »
okay thanks i will do that.
iDemonix
Bike owned: '92 NC30
Post by iDemonix »
Woooh page 100!
I was here, let the legend be told!
Locked
