VFR400 rebuild
Re: VFR400 rebuild
36mm wheel nutlizard821000 wrote:BillingCBR wrote:Don't think it's possible, the heat from baking the PC will melt the rubber seals, which will let the heated (likely liquid) grease come out, which could bugger up the PC, or at best require replacement bearings anyway.
They're under £10 a set anyway, and it's good practice to replace them anyway. Could always pop them out though if they've done very few miles.
If you haven't got a socket yet Halfords should stock a black impact one in 36mm, nice 6 pointed one too, it only cost me about £10 I think
yeah i hear you bill, i could slip the seals off but thats what my worry was, the grease all running out cos of the heat....bollox, shame cos there new for sure! i looked in halfords, they were out, but i ordered one from egay so sjhould be hear tommorrow hopfully. do i need any larger than the 36mm for anything else?? hardnut mentioned a 43mm or somin!? EEKK!!
im thinking now too the burn is just wd but will keep an eye on it cheers all who posted.
shaun
41mm yoke nut
46mm hub nut
22-24mm for front wheel axel nut
Re: VFR400 rebuild
fkin hell!! 46mm!! so here i am waiting for the 36mm to turn up so i can remove my wheel and after iv undone that one i would have hit a 46!! lol fk sake, cheers ricky.....ill get ordering now. was hoping to pull them apart over weekend too. bollox.
Re: VFR400 rebuild
ebays the cheapest place for the said sockets matelizard821000 wrote:fkin hell!! 46mm!! so here i am waiting for the 36mm to turn up so i can remove my wheel and after iv undone that one i would have hit a 46!! lol fk sake, cheers ricky.....ill get ordering now. was hoping to pull them apart over weekend too. bollox.
yeah the axel pulls out the wheel side, once undone.
the hub is held in buy the (big) circlip needs to people to undo as a rule its tight as feck.
and the hub will also need 17mm hex (m14 bolt) removed.
you got my number if you get stuck
Re: VFR400 rebuild
cheers pal, should be fine...just dont own these crazy size tools lol. if i need a 41 aswel i might be better off buying a set.... rather than separate sockets, i looked egay and for a 46mm+adaptor to 1/2 drive your looking at 25 quid min!!! lol so thats 11 quid for the 36 i just ordered and 25 quid for the 46, making it £36 just to remove the rear wheel...... shocking. cheers for heads up about the m14 too, i dont have one of those either
one of these rick... http://cgi.ebay.co.uk/Newsome-1-2-Drive ... 3a64a7096c
Re: VFR400 rebuild
no mate just a normal 17mm socket to fit a HEX head bolt, not allen bolt.lizard821000 wrote:cheers pal, should be fine...just dont own these crazy size tools lol. if i need a 41 aswel i might be better off buying a set.... rather than separate sockets, i looked egay and for a 46mm+adaptor to 1/2 drive your looking at 25 quid min!!! lol so thats 11 quid for the 36 i just ordered and 25 quid for the 46, making it £36 just to remove the rear wheel...... shocking. cheers for heads up about the m14 too, i dont have one of those either
trust me buy the sockets separately youll never need any this big unless your a lorry mechanic,
it would be handy to own sockets bellow 32mm and bellow tho i have 32, 30, 28,27,26,24.22,19,17 and they are all ive ever needed as a rule. most of them com in handy for bearings as driving tools.
Re: VFR400 rebuild
cheers rick, my 150 piece halfrauds set does the job but only goes up to 27mm i think. was looking at buying a 3/4 set but your right, only ever gunna use 1 or 2 times, not enough to justify expensive sets i suppose.
shaun
shaun
Re: VFR400 rebuild
how do i get hold of rick guys??? want to order these frork convertion kit jobs for mine, does he have a website i cant seem to find!? iv heard peeps cant seem to contact him on here either or have trouble, i apricite he s prob a busy lad so does he have a contact number or somin??
cheers, soz for bold writing, it makes peeps read it! lol
Re: VFR400 rebuild
Mate you need a 3/4 set of sockets, you can never have enough tools.
Never had a problem getting hold of rick, sometimes he takes a day or 2 to get back to me but always does. Think his phone number is on the list isnt it??? just call after 6pm
Re: VFR400 rebuild
i bought the sockets separate in the end mate anyways. fk me that 46mm is a monster lol. attempted to remove the hub nut monday with very little luck!!! with a braker bar too!!! i think its a 2 man job.
ill have a scout for his list then if thats the case, my computer dosnt like to open the file most times though for some resson!? ill have a dig about cheers.
Re: VFR400 rebuild
1 more quick question for you guys if i could, would i notice any obviouse markings/fetures if my forks ALREADY had the rick o kit fitted!? or is it all internal.....should prob check inside first befor spending out incase they already have the kit i recon....... is there any picks you lads have of the kit so i can tell if mine are old or ricks ones first, cheers lads.
shaun
shaun
