NC30 rear disc removing question.
Locked
NGneer
Re: NC30 rear disc removing question.
Post by NGneer »
Ersan - note the repeating key words here " A good fitting screwdriver" (or impact driver bit). Make sure the slot is cleaned out so your "good fitting screwdridver" can get maximum purchase and give it a 3 shredded wheat twist and it should break the sticktion and once it has - it will unscrew easy enough.
If you go down the impact driver route - same thing applies. Use "a well fitting bit", make sure the caliper is well secured and a single sharp tap should crack it off and allow you to unscrew it. If you find yourself battering it repeatedly - you are doing it wrong.
Come on Tiger, prove the doubters wrong and do a proper job on that caliper ;)
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
i will do! :D
can anyone recommend me links for piston seals? found these on ebay, will these to me fine?
http://www.ebay.co.uk/itm/Honda-VFR-400 ... 20cd946fcb
bikemonkey
Post by bikemonkey »
I buy OEM ones from david silver, don't fancy trusting eBay stuff on something like brakes.....
speedy231278
Post by speedy231278 »
Two each of these:
http://www.davidsilverspares.co.uk/part ... ber_13668/
http://www.davidsilverspares.co.uk/part ... ber_13669/
Yes, they'll cost you twice as much, and the post isn't free, but unless you trust the seller implicitly that they're not selling cheap Chinese copies and have something decent, frankly for an extra tenner I'd not bother taking the risk. Rick Oliver does aftermarket plugs, pins, pistons and seals, so if you want cheaper copies rather than OE stuff, I'd be more inclined to trust him than some random shop on eBay. Not that I'm suggesting anything untoward about them, it's just that I'm fussy like that... lol
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
bikemonkey wrote:I buy OEM ones from david silver, don't fancy trusting eBay stuff on something like brakes.....
Does it matter in this case?
He doesn't use the rear brake anyway :pmsl:
speedy231278
No, the MOT man will....
:twisted:
xivlia
Post by xivlia »
what difference does it make? rubber is rubber :D
bikemonkey
Ummmmm, no.
It probably won't be as good quality rubber and not a perfect fit.
Fit OEM and you won't have to do it again for a long time.
xivlia wrote:what difference does it make? rubber is rubber :D
speedy231278
I'm sure there's a joke about counterfeit jonnies and unexpected kids in there somewhere.... :whistle:
Locked
