VFR400 rebuild
lizard821000
Re: VFR400 rebuild
Post by lizard821000 »
cheers harvd, i thought it was somin like that!!! math, pffffff. cheers fella.
lizard821000
Re: VFR400 rebuild
looking for some crash bobbins, has anyone got these fitted???
http://cgi.ebay.co.uk/HONDA-VFR-400-NC3 ... 439a03058f
he says no cutting or drilling, which is win!!! but looks like they locate through the fairing bolt hole!? anyone got these or should i go for the R&G and cut my pannels.
cheers guys
also, do the R&G ones mount through the pannels to the engine mount!? like my mito ones do??? ta
lizard821000
Re: VFR400 rebuild
come on lads ^^
anyone using them?
mattUKNC
Re: VFR400 rebuild
Post by mattUKNC »
Personally I don't like those. I'd rather pay for the R&G ones that go lower through the holes in the lowers. They're the expensive ones that have the bar all the way through. :grin: (I'm pretty sure these don't require drilling?! :? )
http://www.bradfordmotorcycles.co.uk/pr ... rotectors/
arsey30
Bike owned: ftr223 650 bros
Re: VFR400 rebuild
Post by arsey30 »
lizard821000 wrote:come on lads ^^
anyone using them?
I was advised that a fall would crack the fairing, not sure if the lower part of the belly pan would be saved.
I took them off, you can have them if you still want them.
Dave.
lizard821000
Re: VFR400 rebuild
WIN!!! if i can get r&g that dont need cutting .
cheers guys, i thought the same, the cheap ones look way too far up the bike!? i dont mind forking out bigger penies for r&g tbh,compared to the cost of new plastics and paint.
im sure iv seen a few diff types if thats the case , some R&G that deffo need cutting, others that folk say dont!? think ill have to call them direct for answers.
thanks for replies fellas. :grin:
alexwitham
Bike owned: 675R, GSXR6, NC30
Re: VFR400 rebuild
Post by alexwitham »
I use the ones from Matt's post. R&G non-drill bungs. Proper solid too, you could pick the bike off the ground with those buggers.
lizard821000
Re: VFR400 rebuild
music to my ears mate!! looks like those are the ones for me. so do they just stick through the holes already in the pannels? i take it the pannels come off to fit the rod, then the bugs can be fitted once the pannels go back on.
cheers boys. i hate cutting my pretty pannels :grin:
alexwitham
Re: VFR400 rebuild
Nah you get 2 alloy plates that attach to a part of the frame, and a bar that goes through the middle which holds the bungs in place. The kit comes with some pretty comprehensive instructions.
lizard821000
Re: VFR400 rebuild
ah, cool. cheers alex. gunna order some this weekend.
shaun
