Valve Clearance Guide
Biscuits
Bike owned: '88 NC24
Location: approaching the apex, carrying too much speed...
Re: Valve Clearance Guide
Post by Biscuits »
Not looking forward to it but I WILL get the clearances sorted and balance the carbs. I've just started working nights so time and money are no excuse. The tapping noise dies off as the engine warms up so I. Guessing it's valve related *gulp*
Formerly RacingSlug. Felt like a change and it came down to either Biscuits, Ben10 (possible copyright issues) or NinjaSmokeWarrior. The wife suggested TwatMan.
Sprinter
Post by Sprinter »
How do you get the shims out if you have quite a few. Remove the cams? Or isit possible to get all the cams at a position to access all the shims?
mattydrvf
Bike owned: Rvf baby
Post by mattydrvf »
you can set the cams to allow access to the frist set of valves change them and then set the cams to a different position to allow access to the remaining valves. Its all explained in these pages have a look through mate.... :peace:
Sprinter
Post by Sprinter »
I realised that about a day after posting. :oops: Cheers anyway. :grin:
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
did mine the other week , it really aint that bad when you get stuck in , just gotta be super careful not to drop the shims down into the engine, slide rocker arms over and use one of them telescopic rods with a little magnet on the end to lift out the shim, crap for gettin them back in tho , i used a little modelling file with a bend in the end with a blob of grease to stick the shim to, done the job perfect, check the gaps and recheck,
Deviants AM/PM build
viewtopic.php?f=62&t=27307
mattydrvf
Post by mattydrvf »
And unlike me remember to take out anything you use to block any holes the shims might fall down. Left a tissue in mine by accident and engine go boom :o :oops: Think it would of been ok if i had of used a cheap tissue but i used bounty, bloody good stuff if you have an oil leek by the way.... :lol:
spooky
Bike owned: nc24
Post by spooky »
Bounty ehh , Which one are you?
mattydrvf
Post by mattydrvf »
I'm the one in a heap in the corner constantly crying.... :cry:
buffalobisonhead
Post by buffalobisonhead »
Hello There,
Would like to check my 94 NC35 valve clearances and am wondering about the tools required.
Which feeler gauges to use, the straight or angled ones?
Can you get one set that will cover the entire range of tolerances for both inlet and exhaust?
Look forward to hearing from you.
micpec
Post by micpec »
As for feeler gauge. I used a 21 blade type straight one from tengtools...that is part.no.FG21 This will cover most of them.
There are more brands and types on the market, from cheaper ones (universal brand from Hein Gericke) to even more expensive ones (gedore).
Check the ratings per blade. For example, if you need to check size 0.17mm, just use blade no. 0,15mm together with blade no. 0,02mm.
