Banoffee's NC30
- alexwitham
Re: Banoffee's NC30
Ill post some up on tonight for you
- banoffee
Re: Banoffee's NC30
I'll probably financially regret you doing thatalexwitham wrote:Ill post some up on tonight for you
- alexwitham
Re: Banoffee's NC30
I have to admit, it does look pretty damn sexy.
- banoffee
Re: Banoffee's NC30
la la la I can't hear youalexwitham wrote:I have to admit, it does look pretty damn sexy.
- banoffee
Re: Banoffee's NC30
just spent a therapeutic couple of hours in the garage tinkering. sorted out the clutch and throttle cable runs to be a bit smoother and neater, had a look under the tank / around the engine+carbs and in the airbox for the first time since I've been running it (no surprises thankfully and the filters are still mint) and replaced a few manky fasteners with stainless ones. oh and cleaned and waxed it
- banoffee
Re: Banoffee's NC30
jackup link has arrived
anyone in the surrey/middlesex area got an Abba or similar stand I could borrow please?
- jamie125
Re: Banoffee's NC30
Whats the advantages of using a jack up kit?
- banoffee
Re: Banoffee's NC30
from my limited research it either gives improved turn-in or enables a 17" rear wheel to be fitted. was only £30 and looks brand new so worth a go
- alexwitham
Re: Banoffee's NC30
You dont need the jack up to fit the 17" wheel, the jackup linkage is just used to compensate for the loss of height with the smaller wheel.enables a 17" rear wheel to be fitted
- banoffee
Re: Banoffee's NC30
ok mr pickyalexwitham wrote:You dont need the jack up to fit the 17" wheel, the jackup linkage is just used to compensate for the loss of height with the smaller wheel.enables a 17" rear wheel to be fitted
