xivlia's thread of nc30 problems and questions
Where posts and threads can be moved to future safe keeping.
Locked
Cammo
Re: xivlia's thread of nc30 problems and questions
Post by Cammo »
xivlia wrote:also... is there anyway of diagnosing the CDI unit on the NC30? or is it just a throw away and buy a new one sort of thing?
There's no way to test it that I know of, it's usually a case of swapping it onto another bike to see if it works properly.
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
magg wrote:The pickups should not touch any part of the starter clutch, in fact I would expect that they a keyed to ensure that there is clearance between them and the starter clutch. What resistance do your "new" pickups measure? For most people diagnosing ignition unit faults is limited to ensuring there is power, ground and pickup signals and then substitute another good unit.
my new pickup shows 399-415 ohms, still less than what the haynes manual says (450-550 ohms) hope they still work.
Bike owned: VFR400
Post by magg »
The resistance values for all things electrical on most cars and bikes are nominal. So long as they are not open or short circuit.
Things like that don't just fail when you've been messing with the bike.
You've either killed the plugs or disturbed something
xivlia
Post by xivlia »
well, all 4 plugs dead at the same time? what are the chances in that.. i hadnt done ANYTHING to the bike... one day the starter clutch broke.... so i changed that and now there is no spark... before the starter clutch broke the bike was working....
Bike owned: VFR400
Post by magg »
If both pickup units are faulty then you will have no spark on any plug. I do not see this as a strange outcome. What I find strange is that both pickups failed at the same time. However if the pickups were being hit by the starter clutch as it rotated that could damage them.
Or you've installed the starter clutch wrong so the timing is out and its' not sparking athte right time.
nc30chris
Bike owned: '92 nc30
Post by nc30chris »
i have to say this thread makes a very interesting read, think if i was this unlucky id give up all things that have engines! frank spencer springs to mind!!
on the sparking issue, i recently had an issue with mine after i had partly stripped it down, where i had removed the l/h crash bung it left a small plate with an earth lead attached adfirt from the engine case, spent ages trying to find out what id done, and eventually worked out that i had basically disconnected the earth by leaving the bracket un attached, thus giving me no spark on any cylinder, i refitted the plate via the crash bung and it fired up straight away! might be worth checking you havent made the same mistake as me, not sure if you have done anything in that area at all. its worth listening to the other guys on here, and checking what they say, there is some very experienced people on here who know there stuff! keep up the good work though, think id miss this thread if it ever finishes!
Trinirides
Bike owned: NC30 is all you need to know
Post by Trinirides »
Ive done the exact same thing, PITA and such a easy thing to over look!!!!! :wanker:
A wise man once said, Man who goes to bed with itchy bum hole wake's up with smelly finger
xivlia
Post by xivlia »
i did remove my crash bungs... but i am having trouble understanding what he means by the bracket etc....
Locked
