Page 66 of 112
Posted: Sun May 13, 2012 10:26 pm
by xivlia
checked the cdi aswell, no problems there. one thing, does the stator control the sparking on these bikes aswell? maybe ive burnt the stator... didnt check that at all.
Posted: Sun May 13, 2012 10:57 pm
by porndoguk
Your doing your trick if asking a question, then asking more questions without checking out the answer of the first question in hand,
Pick ups, go check, they are the sensors that signal to cdi, to then signal to the coils to pulse a spark charge.
Stator goes to the rectifier, turning 50v ac to 12v dc that is all
Posted: Sun May 13, 2012 11:03 pm
Kill switch
Posted: Sun May 13, 2012 11:08 pm
by xivlia
http://www.ebay.co.uk/itm/HONDA-VFR400- ... 1c24b7ae7f
that is the pulse generator coil ... or pickup as youd call it? right.
Posted: Sun May 13, 2012 11:12 pm
by porndoguk
CMSMJ1 wrote:Kill switch
Forgot about that,
Thats happened to me before go get ya slippaz and dressing gown on, go check now!
I did at 1am in my boxers when spent hours trying to get her to start when i realised in bed, couldn't sleep without knowing
Posted: Sun May 13, 2012 11:18 pm
by xivlia
kill switch is on the on position. but i will disconnect that and see if that is the cause......
Posted: Sun May 13, 2012 11:26 pm
by xivlia
nah kill switch is fine.. the pulse coils are fucked im getting way too high resistance from them
Posted: Sun May 13, 2012 11:32 pm
by magg
If you disconnect the kill switch you will remove power to the ignition unit. Have you checked for 12 volts on the black/white wires at the ignition coils and the ignition unit?
Posted: Sun May 13, 2012 11:46 pm
by xivlia
i disconeected the kill switch, but then the ignition wont work, so i reconnected it. but i had checked the ignition coils and CDI and they were all fine. i think my main problem is the pulse coils.
Posted: Mon May 14, 2012 12:28 am
by magg
What was the resistance reading? Unusual to have both trigger coils fail at the same time. Do you disturb them while changing the starter clutch?
